Hey all it has been unfortunate in the past we had to cancell the newie cruise due to possible riots at newcastle.
well this is our chance to try it again :P
SYDNEY TO NEWCASTLE & Meeting Newie Crew, Meeting with the Newie Crew
DATE: 23rd April (Sunday) 2006
Meet: P6 Homebush Olympic Park
Time: 10am Departure:10:30
List so far:
1. = SUPERMAN = - Jeffro (organiser-Will be in a BLACK SS ute)
2. Alien- Darko + HI>PSI CREW (organiser)
3. Lingeringsoul- James
4. Taran-Taran
5. Freeman + 1
6. N1GTR- Steve O
7. Henzie- Henry
8. Satanic- Stan + guest (project car)
9. NXTIME- Charlie
10. MR32- Norm
11. Gtr Glafche
12. LIZ- Elizabeth :D
13.Evil Weevil- Chris
14. weapn
15. Miiz Skyline- Manda
16. Trust33- Graig
17. Phatsky32r- Nathan
18. doodz- Victor
19. Miss Turbo- Liz Jane
20. Teckno- Teck
21. MAR55S>
22. jap32r
23. sindows
23- donnie + 3 liners
24- veeedka- Victor
25- iqnuz
26. N1 R33 GTR
27. NYL83R
28. ih8vls
29. Primordial
30. Godzgtr
31. burnsie
32. GTRsean
33. Cro boy Mario
34. toyboy4u
35. staunch
MAYBE's:
1. DRFTD 32
2. rb30gtr
3. vuey
4. DIF- Corrine
5. patto1234
RULE: Please have respect for other road users, please do not put other peoples life in danger. Please obey the road rules, we don't want people to ruit this day for us
RE-GROUP INFO
-We will re-group as soon as we get off the Newcastle Exit after the 1st Roundabout
-Please try not to stop on the F3 as it will be too Dangerous to get back on the road, specially if we are trying to merge as a big group.
Dont worry we will wait for you when we re-group
(more info will be added, maps etc)
Edited by = SUPERMAN =
https://www.sau.com.au/forums/topic/109467-sydney-to-newcastle-cruise-part-3/
  • Replies 283
Posted Images
Hey all it has been unfortunate in the pass we had to cancell the newie cruise due to riots at newcastle.
SYDNEY TO NEWCASTLE
DATE: 24th April (Sunday) 2006
List so far:
i should be able to make it.
Im in depending if im in sydney off work, will be good, i will organise more cars from newy, and also sydney to join us up on foreshore,
Fingers x'd
That will be good, ill let some of the newie crew also that we are coming.
    • My thinking is that if the O2 sensor is shot then your entire above described experience is pure placebo.
    • Here is the mess that I made. That filler there was successful in filling dents in that area. But in the middle area. I can feel dents. And I've gone ocer it multiple times with filler. And the filler is no longer there because i accidently sanded it away. I've chased my tail on this job but this is something else lol. So I'm gonna attempt filler one more time and if it doesn't work I'll just high fill primer the door and see where the issues are because guidecoat is of no use atm.
    • Ok, so I think I sort of figured out where I went wrong. So I definitely overthinked it, and I over sanded, which is probably a large part of the problem. to fix it, I ended up tapping some spots that were likely to be high, made them low, filled them in, and I tackled small sections at a time, and it feels a lot better.    I think what confused me as well is you have the bare metal, and some spots darker and some are lighter, and when I run my finger across it, it' would feel like it's a low spot, but I think it's just a transition in different texture from metal to body filler.    When your finger's sliding on the body filler, and crosses over to the bare metal, going back and forth, it feels like it's a low spot. So I kept putting filler there and sanding, but I think it was just a transition in texture, nothing to do with the low or high spot. But the panel's feels a lot better, and I'm just going to end up priming it, and then I'll block it after with guide coat.   Ended up wasting just about all of my filler on this damn door lol
    • -10 is plenty for running to an oil cooler. When you look at oil feeds, like power steering feeds, they're much smaller, and then just a larger hose size to move volume in less pressure. No need for -12. Even on the race cars, like Duncans, and endurance cars, most of them are all running -10 and everything works perfectly fine, temps are under control, and there's no restrictions.
    • Update: O2 sensor in my downpipe turned out to be faulty when I plugged in to the Haltech software. Was getting a "open circuit" warning. Tons of carbon buildup on it, probably from when I was running rich for a while before getting it corrected. Replaced with new unit and test drove again. The shuffle still happens, albeit far less now. I am not able to replicate it as reliably and it no longer happens at the same RPM levels as before. The only time I was able to hear it was in 5th going uphill and another time in 5th where there was no noticeable incline but applying more throttle first sped it up and then cleared it. Then once in 4th when I slightly lifted the throttle going over a bump but cleared right after. My understanding is that with the O2 sensor out, the ECU relies entirely on the MAP tune and isn't able to make its small adjustments based on the sensors reading. All in all, a big improvement, though not the silver bullet. Will try validating the actuators are set up correctly, and potentially setting up shop time to tune the boost controller on closed loop rather than the open loop it is set to now. Think if it's set up on closed loop to take the O2 reading, that should deal with these last bits. Will try to update again as I go.
