Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
I'm so mean to myself because the last 19 years I've been put down by people I used to trust.
That being my (ex) best friends in highschool who decided to **** my final year of school by calling me a fat whore. And I never went anywhere cause I was too fat. Well I am now after I put on like 20 kilos from there shananigans.
Also, when I drive around in my car, people say after I've driven past "did you see how fat she was"
Things like that really put you down and it's hard to love yourself and make yourself happy when people insist on making peanut gallery remarks that have a big effect on me cause of those stupid whores from highschool who shot my selfesteem below nill cause they were too insecure in themselves to think about anything else *breathes*
Originally posted by MM2death
Hey anyone know of a good place to get good priced new or 2nd hand intercoolers around Brissie...preferably to suit R32 or 33.  Anyone except ARE or PWR.
Thanks,
Scott.
I got a quote of someone for a full intercooler kit to suit my car (i'm pretty sure he does R32's as well) for $1550. Thats a bar and plate intercoooler/end tanks/piping/polished and silicon joins AND FITTING..
Brand New. I thought that was an excellent price :D
I just gotta find the money somewhere to get one!!
well u aint fat compared to me :D im pretty bad hey, i guess im kinda lazy, but ive started a new routine man, just gotta have sum self esteem, i really hate ppl when they say things but i just ignore them and know one day ill be sumwhere and they will be no where
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
