Queensland Wasteland
  • Replies 28.4k
  • chaos
    4853
  • BelGarion
    4045
  • GTS-t VSPEC
    2546
  • rb25
    2007
pet duck? awww i always wanted a pet duck - guy in year 10 promised me one off his property but i never got it :D
sounds like me - happy when im eating. My poor cat is going to have her last spoonful of Whiskas tonight - might have to swing by the shop n get her some more on way home. My cats a big female!! she squashes me!
I dont wanna say I'm sorry
Cause I know theres nothing wrong
DOn't be afraid
There's no need to worry
Cuase my feelings for you are still strong
HOld me in your arms
and never let me go
Hold me in your arms
Cause i need you soo
I can see it in your eyes
there is something
something youw anna tell me
See it in your eyes
There is something
taht you hide from me
is there a reason why
there is something
something you wanna tell me
i see it in your eyes
there is something
that you hide from me
Cause I knwo theres nothing wrong
Don't be afraid
thers no need to worry
Cause my feelings for you are still strong
HOLD ME IN YOUR ARMS
And never let me go
Cause I need you soo
there is something
there is something
Is there a reason why
there is something
I see it in your eyes
there is something
that you hide from meeeee.....
no it would make u worse so its good u dont.
just unfortunately know people that do them and they sound a bit like u. Hows shit their life is etc etc etc ....... my ex was one of them. :D
    • Keeping in mind that for most people this is a week to month long job!
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
