Thanks Adrian, I do have set of Stagea 16" wheels, same size as R33GTST. I was thinking more along the lines of R32GTR rims as they are 8".
The taller sidewall is a thought, have you compared the 255/50/16's and the 275/40/17's times? Is there a noticeable difference? It's a width versus sidewall comparison, which gives the best result.
I have a pair of ugly 17 X 9" with a serious 45 mm offset, on those wheels the 275's would have no problems outwards, maybe inwards would be an issue though. That's what I have to measure.
cheers
Gtr rims are spot on. Reason for the 300ZX suggestion is a price thing. If you already have a pair they would be perfect. Much lighter (i believe) than the 300 rims.
The problem is not usually with the outer guard. The inner guard and spring are the points of contact if at all. You shouldn't have big -'ve camber on the back for drag racing anyway so standing the wheels up can help a couple of problems at once.
I have run similar times on the 275's and the 255's BUT I ran within thousandths of my best 60' time on the 275's on my first pass with the 255's. Stickers left on and all :P
Adrian
  • Replies 77
Posted Images
I have run similar times on the 275's and the 255's BUT I ran within thousandths of my best 60' time on the 275's on my first pass with the 255's. Stickers left on and all ;)
Adrian
Thanks Adrian I will do some measuring on the weekend. Sounds like the taller sidewall of the 255/50/16's wins over the extra width of the 275/40/17's. 255 X 50% = 127.5mm, versus 275 X 40% = 110 mm.
Yep, the standard Stagea rims are forged. I will adjust out any static negative camber, plus I will dial out some dynamic camber change as well. Are the 275/40/17's actually 275 mm wide? I have a pair of 255/40/17's that are 250 mm, and a set of 4 X 245/40/17's that are actually 260 mm wide. Tyre companies can't measure :(
We will be using the tyres on the road R33GTST and the race R32GTST, so they will get some use.
:) cheers :D
Edited by Sydneykid
i need 255/50/16 for my rears
235/50/16 for my front
let me know when these will be avalible and if we can run these on the street.
Ta, Josh
255/50/16 is available, but 235 is only made in a 15'. 235/60/15.
Tyres are 100% street legal.
If they are the same as other "drag" tyres I have used in the past, they may well be "legal" for street use but not "recommended". They have limited tread depth and pattern, so not so good in the wet. Also the carcass is designed for straight line traction, not going around corners. What I intend to do is put them on and drive to the track, race, then drive home and change them.
That said, plenty of guys drive around with them on all the time, but they are soft and wear out fairly fast. Plus I would be concerned with what the large number of heat cycles will do for the traction when I need it on the track.
:laugh: cheers :D
[PART # SIZE COMPOUND APPROX.
WEIGHT MEASURING
RIM SIZE
EQUIVALENT SIDEWALL
WIDTH TREAD
WIDTH OVERALL
DIAMETER
CIRCUMFERENCE
3793R P255/50R16 R2 28 8.0 26x10.50R16 10.5 9.7 26.0 82
3743R P275/40R17 R2 28 9.0 26x11.50R17 11.0 10.2 26.0 82
The 255/50/16 on an 8" rim is 10.5" wide inc sidewall bag, the tread width is 9.7"
The 275/40/17 an a 9" rim is 11.0" wide inc sidewall bag, the tread width is 10.2"
Time to do some measuring
:D Cheers :P
Results are in:
Monas R33 sixty footed at 2.0 secs on street tyres and was running around 12.6 at 107mph.
Ran 1.75 sixty foot, and 12.4 at 110 on a MT 255/50/16 street radial. Backed these times up on a second run also.
Fair to say that three tenths in the sixty is a fair improvement.
Adrian was also sixty footing in the mid to high 1.7 secs last night, ran 11.8 @ 117mph.
For further enquiries or to order a set of tyres I can be contacted on 4226 1888 or 0425 349923.
Will provide bank details for direct deposit if necessary. Can arrange freight.
I think the MT website mentions ACTUAL widths on a fixed width measuring rim.
Adrian
Well!! was out a WSID last night to test out those drag radials!
Best run of the night with street tread:
60': 2.030
MPH: 107.90
ET: 12.663
Best run of the night with Drag Radials:
60': 1.751
MPH: 110.86
ET: 12.418
Pity it rained as the official said he'd get me in for another two runs!!! :P Could have easily done better times on the drag radials, but the car was experiencing some probs... it didn't really like that 100ron fuel.. oopss!!!
THANKS TO STUART AND THE BEZERKLY BOYS for giving me the oppourtunity to try out those radials... they definitely improved 60 foot times and i know my car could easily do 12.1/12.2 on a good day! :D
Ok guys, got some pricing.
235/60/15 $235.00ea
255/50/16 $250.00ea
275/40/17 $275.00ea
Ok people, who's keen, id like to order these tyres soon as so the people who have already commited to buying a set can collect them next week. prices are as shown. can contact me via email , [email protected] or PM me or Ph 0242 261 888 or mob 0425349923
This boat will sail and you will miss out on a genuine bargain.
235/60/15 $235.00ea
255/50/16 $250.00ea
275/40/17 $275.00ea
Ok people, who's keen, ordering these tyres on monday afternoon so the people who have already commited to buying a set can collect them next week. prices are as shown. can contact me via email , [email protected] or PM me or Ph 0242 261 888 or mob 0425349923
Edited by Bezerkly
Mine were delivered today.
I haven't seen them yet
Reports are they are black, round and sticky
What more could you want?
Thanks for organising the Group Buy
:P cheers :rofl:
  • 1 month later...
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
