I have a Skyline GTE (RB20E Auto) and have put a GTS (RB20DE Manual) motor and manual gearbox into it.
all was straight forward apart from the wiring. It wont start because (ive been told) it thinks its in drive. What do i do, do i bridge wires or what? and what wires do i bridge.(photos would be good).
Also my reverse lights dont come on when i put it into reverse and how the hell do i fix this problem, its pissing me off
THanks
https://www.sau.com.au/forums/topic/110327-auto-manual-conversion/
Can't give you photos. However, you need to find the 2 wires that were connected to the "don't start if it's not in Neutral or Park" switch (that's the technical name, more commonly referred to as ?? - is it the safety switch? - I'm not really an auto person). Just connect them together so the ECU thinks the (auto) gearbox is in Park.
Similarly for the reverse lights, find the 2 wires and hook them into the reverse switch. Or maybe the reverse switch is broken.
Here is a photo.. I am just in the process of converting mine to manual, amongst other things..
I just labelled them based off the old auto shifter, and I think I've got it down. But could be wrong..
So you just gotta find out which one isn't 12v when the lights are on (the globe), and I think the other two are your park switch. Bridge them together.
For your reverse lights, you're going to have to hook into your gearbox reverse wires.. I think its the sensor at the back of the box..
Anyhow, I gotta play with it all and work it out myself.. when i do I'll post it up somewhere.
hey
i just finished convertin my rb30 2 manual it should b the same not 2 sure but ill c if i can help, i cant give pics as it might b different.
well 2 solve the neutrel switch prob i found the wire that runs from the the started motor it should run up past ur battery and have a plug might b black and yellow, well unplug it and ull have 2 run a wire from the wire off the starter motor 2 ur key should b the same wire colour, this basically bypasses the nutral switch. thats if u want 2 cut wires and so forth if not just loop the plug underneath or connect it 2 the back plug 1 b4 speed senser if its the same i really dont no.
and as 4 the revers its the front plug on the box if its the same lol, just find the plug that went in2 the auto should have ur speed senser wires in it, it should b from the back of the box speed, nuetral and revers i think neway if ur un sure of this check th manual book 4 help should give some help.
well i do hope this has help in some way. blue demon.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
