^ all good my boss mate found the bolts in bunnings... anyways results of clenaing the AAC is freaking awesome !!!!!! my car was like idle at 600 rpm for the last year or so and always started hunting when I used Aircon/heater this has fixed everything, cars running good as new !!!!!!!!!! thanks for the write up great guide.
Your mate sounds like his pretty awesome :D
  • 2 months later...
  • 1 month later...
I was having issues with a rough idle after start. Revs were sitting at 4-500, or the car would cut out. I'd blip the throttle, then they would pick up to 1200 or so before settling down. I came across this thread whilst troubleshooting, and it sounded like the AAC valve needed cleaning. However, I found a leak on the vacuum line between the throttle body and charcoal canister (tiny...only a few mm), Replacing that hose has fixed the problem. Sure it has been said in this thread before...but check for leaks, might save you unbolting the AAC!
  • 1 month later...
  • 10 months later...
  • 4 weeks later...
  • 2 months later...
  • 7 months later...
  • 1 month later...
I wanna give my a car a clean this weekend too. If the gasket is not really re-usable, can we use one of those tubes you get at auto stores for making your own gaskets? Also should it be hardening or non-hardening?
On another note though could someone help me out with what the hell is going on with my aac valve? This is the third one that I put on there because I thought something was wrong with the aac valve itself, at idle it keeps on hunting as in the revs go up to about 2000 then down to 1000 up and down up and down, if I turn the headlights on it idles fine at 1000rpmish, I've just unplugged it for now and it's idling at 900 bit i really want to get it sorted out as its getting hot and when I turn the ac on the aac valve being unplugged doesn't compensate for the rpm drop, thanks.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
    • @Duncan I can try  and thanks i did not thought about VIN and part numbers for 33/34. @GTSBoy yeah it looks like iam gonna do that
    • Forgot to include this but this is the mid section of my steering rack that looks like it has a thread/can be turned with that notch mentioned in the post:
    • Hey everyone, Wanted to pick some brains about this issue I'm having with rebuilding my 33 rack (PN is 49001-19U05). All of the tutorials/videos I've seen online are either R34 or S Chassis racks which seem to be pretty straightforward to disassemble but this process doesnt carry over to my rack. Few of the key differences that I've noted The pinion shaft on the other racks bolt on with 3 torx bolts: Whereas my rack bolts on with 2 allen head bolts: These changes are pretty inconsequential but the main difference is how you pull the actual rack out of the housing. The other skyline/s chassis racks can be taken out by tapping the rack out of the body with a socket and it just slides right out. I'm unable to do that with my rack because there's a hard stop at the end that doesn't let the seal/shaft be tapped out. Can also see a difference in the other end of the rack where mine has a notch that looks like you're able to use a big wrench to unthread 2 halves of the rack whereas the other racks are just kinda set in with a punch. My rack: Other racks: TLDR; Wanted to know if anyone has rebuilt this specific model of steering rack for the R33 and if there were any steps to getting it done easier or if I should just give this to a professional to get done. Sorry if this post is a bit messy, first one I've done.
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
