Hi all, i have a question, my 25, i built it, got it tuned (about 320rwkw), found out about oil problems, got scared and pulled engine out to fit restrictors and make sump bigger. To my horror the bearings were totally shot, and had been running dry at times obviously, anyway thats sorted, whole bottom is getting blueprinted as we speak. But what i want a second opinion on is, is putting a scavenge pump from rear of sump pan to front unnessisary? Iv made sump bigger, about 1.5L, and its baffled and gated, modified pickup, i have tomei pump set to 65psi. head restrictors, rear head drain etc. Reason i worry is when i do a hillclimb race of any sort, when pulling huge revs for really long times up really steep hills, will the oil flow back to front of sump? or is it a worthy setup? Its predominantly driven sensibly on the road, but i will do the odd race and track and skidpan day.
Now everyone will say go dry sump... Iv considered it, not going to do it the aircon is too valuable around here. plus its pretty dear. And i dont bash the limiter, so the tomei should serve me well. Iv probably missed some details... thanks
No i havent yet, but they look great? nothing restrictive about them. or do i need to take them oversize?
Now, plenty of oil?
Does anyone know if overfilling a bit is bad? what happens if your crank slaps the oil?
Now, plenty of oil?
Compare the half a dozen tiny oil drains in the RB to the 12 x 14mm oil drains in a JZ
So yes they are restrictive, most guys drill them out by 1mm as there isnt much room to move.
So drilling out the drains in the head and block. How do people actually go about doing this?
Just grab the power drill, a 9mm drill bit, some cutting fluid and go nuts?
Do they get a workshop to do it.
Or use a suitable drill press?
ok so no real problem with an overfill, ill attack the drains on weekend.
Has anyone experienced oil problems with restrictors and head drain with bubbles or starvation up really steep hills with big power?
I was going to use a 10mm bit unless anyone knows better?
This is for the rear drains yes, but what do people do about the 8?mm holes in between the cylinders?
As above run a 10mm bit through although it would be nice if someone could confirm having done it themselves.
I run 10mm, no probs at all.
die grind rear drains, drill others as they are round
Edited by jangles
The question still remains though. do people just get out the power drill with some cutting lube and drill out the drains to 10mm in the head and block and then chamfer the holes with a deburing bit.
Or do they get a machinist with a drill press/cnc to do it?
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
    • I've managed to find this: Nissan_Stagea_AutechVersion260RS (1).pdf
    • I believe @Duncan has given it a crack at Mt Buller before (in actual race conditions)
