Here are all the parts i think i have...
I have to put prices on, SORRY... i really dont know what they are worth, so ill guess.. make me offers
R33 Std Dump $50
R33 Std intercooler $50
R33 Fan $50
R33 Turbo - Great condition... ***SOLD***
R32 Exhaust Manifold $50
R32 Alternator $70
R32 Crank Angle Sensor $? ***SOLD***
R32 Air Fuel Meter $50
R32 Coil Packs x 6 $200
R32 Std Injectors $100
R32 Wiring Loom $100 ***SOLD***
R32 Fuel Rail $? ***SOLD***
R32 Fan Belt Pulley $?
R32 Fan $50
There is pics of most the parts...
Please give me offers.... i have to sell this stuff, but please no REALLY stupid offers
PM or call 0409875864 Troy
https://www.sau.com.au/forums/topic/110690-garage-cleanout/
Hey buddy, what's the condition of the R32 alternator? Need a good condition unit, and I'm also in melbourne. Pm me with any info you have.
May also need you AFM, if that's in good condition. pm me with info on that too if possible.
Thanks mate,
George.
Edited by OREX
https://www.sau.com.au/forums/topic/110690-garage-cleanout/#findComment-2040095
the turbo is off an RB25? wicked...
How can you tell that for sure.
I guess that explains why it didnt live up to the reputation of being a crap RB20 turbo and breaking, lol.
Anyone want it then?
https://www.sau.com.au/forums/topic/110690-garage-cleanout/#findComment-2096513
    • Starter motors used to use the weight of metal (magnets) to provide torque. Now they use (more) current instead. This. It's completely normal.
    • So thing that had me stumped, but I think is OK....is that when it was up in the air, in neutral I had it running to bleed to coolant while I put the wheels back on. I noticed the rears were turning (slowly) which I'd never seen before 20250928_163512.mp4     Because there had been an issue with clutch slip due to pedal adjustment on the dyno, I assumed there was still and issue so spent some quality time upside down under the dash adjusting the pedal....but no matter what I did the wheels still turned in neutral. Even disconnected the master cylinder to pedal rod and same. In despair, I even removed the clutch slave so there was no chance of any preload causing it.....still happened. So either: 1. Something is not right in the bellhousing, or 2. Its a thing sometimes with cold, thick gearbox oil Internet says it might be 2, I hope so!
    • OK, few more things sorted and it is ready for a shakedown on 10-Oct, with one weird thing. Changed the run in oil and filter for the good stuff. 8l came out, about 8.5 went in with filter so that looks all good. Changed the starter (again), this time for a brand new one, works good. Interesting that the Taaaarks one is shorter than factory but spins harder, I guess electronics have moved on a little in the last 30 years. Will be nice to have a bit of extra space under there. Put the timing cover back on, and noted where the cam gears were set as a record.  Will need to double check the timing but it is pretty close. Also put the coil pack cover and intake snorkel back on. Exhaust Inlet Changed the water out for coolant, bled up nicely. Removed the rear brake pads (well worn factory sumitomo ones!), gave the hardware a good clean and reassembled. I've put bendix XP on the back again because the price is excellent at $150 a set and they worked well on the V37. Front pads have plenty so no issue there
    • Mine is all -12, I’m running a dry sump in a billet block though
