r32mspec Posted February 25, 2003 Share Posted February 25, 2003 My 32 has a loud high pitch scream comming from, well I thought the turbo, orig, I thought it was the belts, factory ones were cracked and hard, changed belts to bosch items, but noise continued, it at first only happened under big loads at 4500rpm foot flat but now screams at lighter loads 3800rpm 2/3 throttle about 5psi, I can still get full boost with hardly any throttle without it, it is definately boost related. A friend however today told me that it could also a split in a plumbing joint, has any one ever heard of this happening before? Link to comment https://www.sau.com.au/forums/topic/11078-sreaming-turbo/ Share on other sites More sharing options...
KamikazeR33 Posted February 25, 2003 Share Posted February 25, 2003 yeah it sounds like it could be a leak somewhere in the pipework Link to comment https://www.sau.com.au/forums/topic/11078-sreaming-turbo/#findComment-183066 Share on other sites More sharing options...
r32mspec Posted February 25, 2003 Author Share Posted February 25, 2003 If it was the turbo but, and i am still getting boost what would it be bearings? I just read a fast fours mag artticle about the bbearing r33 turbo and they recon the bearing unit is pretty good, Quote "should out live the engine". I don't have a turbo timer yet but always give it 3-5 minutes on cool down after a flogging. Link to comment https://www.sau.com.au/forums/topic/11078-sreaming-turbo/#findComment-183402 Share on other sites More sharing options...
r32mspec Posted February 26, 2003 Author Share Posted February 26, 2003 It was the turbo, Just went out for milk and came home with no boost, recon my cat is full of ceramic exhaust turbine blades, Just for reference was running 14 psi at the plenum apparently to much, still lasted for 3months. Time for something bigger. Link to comment https://www.sau.com.au/forums/topic/11078-sreaming-turbo/#findComment-184680 Share on other sites More sharing options...
int21h Posted February 26, 2003 Share Posted February 26, 2003 Bugger dood! Did you boost it to 14psi? Link to comment https://www.sau.com.au/forums/topic/11078-sreaming-turbo/#findComment-185379 Share on other sites More sharing options...
r32mspec Posted February 27, 2003 Author Share Posted February 27, 2003 Yes, had my boost guage reading from the plenum, mabye should have set it up on the wastegate actuater pipeing as i think their is pressure drop through all the intercooler plumbing and the actual boost at th turbo's outlet would have been more like 15psi which is apparently too much. Also the cheap style boost control valve i'm ussing can give boost spikes to 15.5psi my guage. Link to comment https://www.sau.com.au/forums/topic/11078-sreaming-turbo/#findComment-186424 Share on other sites More sharing options...
BOOSTMEISTER Posted February 27, 2003 Share Posted February 27, 2003 My guess's....missing/broken exhaust manifold stud/bolt/nut OR perhaps the a/c pulley has seized, that's the two things that happened to mine and they both made the above mentioned noise. Link to comment https://www.sau.com.au/forums/topic/11078-sreaming-turbo/#findComment-187132 Share on other sites More sharing options...
Guest nismogtsx Posted February 28, 2003 Share Posted February 28, 2003 Mine is due to a japanese man filing the front tip of the turbine... Aparentlly they do this for rice factor. The air rushing past causes a very high pitched turbo squell.... I have had mine now for 12 months running 10psi and have had no turbo trouble and many have said it will let go soon. I will drive it til it dies... Or i win lotto Link to comment https://www.sau.com.au/forums/topic/11078-sreaming-turbo/#findComment-189294 Share on other sites More sharing options...
KILL HSV Posted August 22, 2004 Share Posted August 22, 2004 It was the turbo, Just went out for milk and came home with no boost, recon my cat is full of ceramic exhaust turbine blades, Just for reference was running 14 psi at the plenum apparently to much, still lasted for 3months. Time for something bigger. r u getting a new turbo? or r u just going to get a steel wheel for the exhaust side and get it repaired? did u have the car when it was on stock boost? or did u buy like that? and if u boosted it, then was the car running well on stock boost, cos i'm planning on leaving mine on stock boost for a while, until i either change the wheel or the turbos for something quicker, also when u fix it can u post up how the engine runs, cos another post here says that shit can get into the engine and kill it. Link to comment https://www.sau.com.au/forums/topic/11078-sreaming-turbo/#findComment-986787 Share on other sites More sharing options...
martydaman Posted August 22, 2004 Share Posted August 22, 2004 dude... talk about dug up... check the post date man, i think the problem would of been solved by now Link to comment https://www.sau.com.au/forums/topic/11078-sreaming-turbo/#findComment-986800 Share on other sites More sharing options...
KILL HSV Posted August 22, 2004 Share Posted August 22, 2004 woops i searched it and didn't even think about that. still like to know how it turned out though Link to comment https://www.sau.com.au/forums/topic/11078-sreaming-turbo/#findComment-986952 Share on other sites More sharing options...
R31 POWER Posted August 28, 2004 Share Posted August 28, 2004 Yer me to. Link to comment https://www.sau.com.au/forums/topic/11078-sreaming-turbo/#findComment-992639 Share on other sites More sharing options...
Roy Posted August 28, 2004 Share Posted August 28, 2004 He is a traitor, he sold his very neat and tidy 32 GTST for a GTR, at least its still an R32 Link to comment https://www.sau.com.au/forums/topic/11078-sreaming-turbo/#findComment-992723 Share on other sites More sharing options...
letemlaf Posted August 28, 2004 Share Posted August 28, 2004 dude... talk about dug up... check the post date man, i think the problem would of been solved by now :idea: Link to comment https://www.sau.com.au/forums/topic/11078-sreaming-turbo/#findComment-992995 Share on other sites More sharing options...
