Looking for a replacement for my rb20 turbo which is slightly or a fair bit bigger than the 20 turbo!
Not looking to spend alot as im simply replacing a blown turbo and it will only be a tuned on an safc!
Any info can b directed to [email protected]
Thanks all
Jaz
Ive got a highflow rb20 turbo on my car now. Im going to be looking at pulling it off soon to get something larger.
Its had about 10k kms on it, and it cost $1200 to highflow. It has larger steel wheels, and has been machined out to fit. Ive been told its sort of like a t3/t4 hybrid (but its still a rb20 highflow)
It makes similar power to a hks2530 i think, and has the same response as the std turbo has.
Im looking to sell it for around $950 (ono) so if your interested, let me know and we could work something out.
Pics below show turbo when i fitted it to my new motor. It runs fine, and has no shaft movement.
Edited by Bl4cK32
As i said in my PM Bl4cK32 im happy to take the turbo, just buzz me when its off the car. Anyone with any similar offers that have the turbo off the car is free to PM me aswell as cash can't exchange hands until he takes it off and is ready to send it to me!
Ended up deciding against that dude (after i made the thread hints the title... lol)
Looking for something simlar to the pictures of the hi-flowed unit above.
Thanks for the offer :ermm:
    • This is how I last did this when I had a master cylinder fail and introduce air. Bleed before first stage, go oh shit through first stage, bleed at end of first stage, go oh shit through second stage, bleed at end of second stage, go oh shit through third stage, bleed at end of third stage, go oh shit through fourth stage, bleed at lunch, go oh shit through fifth stage, bleed at end of fifth stage, go oh shit through sixth stage....you get the idea. It did come good in the end. My Topdon scan tool can bleed the HY51 and V37, but it doesn't have a consult connector and I don't have an R34 to check that on. I think finding a tool in an Australian workshop other than Nissan that can bleed an R34 will be like rocking horse poo. No way will a generic ODB tool do it.
    • Hmm. Perhaps not the same engineers. The OE Nissan engineers did not forsee a future with spacers pushing the tie rod force application further away from the steering arm and creating that torque. The failures are happening since the advent of those things, and some 30 years after they designed the uprights. So latent casting deficiencies, 30+ yrs of wear and tear, + unexpected usage could quite easily = unforeseen failure. Meanwhile, the engineers who are designing the billet CNC or fabricated uprights are also designing, for the same parts makers, the correction tie rod ends. And they are designing and building these with motorsport (or, at the very least, the meth addled antics of drifters) in mind. So I would hope (in fact, I would expect) that their design work included the offset of that steering force. Doesn't mean that it is not totally valid to ask the question of them, before committing $$.
    • The downside of this is when you try to track the car, as soon as you hit ABS you get introduced to a unbled system. I want to avoid this. I do not want to bleed/flush/jack up the car twice just to bleed the f**kin car.
    • But again, the engineers said your cast aluminium would be fine based on the load that would be stretching that section. Same load stretching the bolts in a flex (not the twist), with a much smaller cross sectional area than the original part you've broken. It's why you'd need to be using higher strength bolts, but that's just making up for the strength you lose with less area...
    • I am truly amazed someone on this planet was able to cycle the pump using a scan tool. I've always ghetto cycled them on Nissan 90s shit boxes by slamming the brakes and pulling the handbrake to agitate the rear wheels enough to cause a speed difference
