  • Replies 82
umm...i used it so long ago, havent used it since...but like i said, i dont know how to use it properly, so i basically found the MCG in the city, or any other big landmark you know of...then i basically scrolled my way across the maps until i found the freeway out of the city towards geelong...took my hoppers crossing exit and basically scrolled to my house...not the easiest or quickest ways to find stuff i'm sure, but it worked. lol
is the images upgraded all the time or are they the same permanently?
They started taking them in 2001 and finished the earth in early 2003
Now they are using heaps of different satalites to take pictures which is why you see down the bottom of the screen the rights change eg "Google Earth 2006"
Well regardless of how cool all that is i found my banana parked out front of a friends house :wub:
It is a little hard to see but it's there!!!
Matt, Sorry to piss on your parade, but you do realise that these maps are 2 - 3 yrs old (for obvious reasons - ie nasty people who like to plot mayhem).
If you don't believe me, think of some big construction project or new housing estate that's less than 2 yrs old and see if it's there.
actually ur wrong, i can c the constuction for the albury bypass which started 8 months ago
also the epping bypass is in there also :wub:
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
    • A bit late but A disk S13P fit over stock R32 GTR brakes, usually A disk front, O disk rear works.
    • Or, the height of the release bearing is not correct for your combo. Start with the bleeding and checking the slave moves throughout its range when you press the pedal (2 person required), but it is possible for the height to be internally wrong too (box back off to measure.
    • Yes, there's quite a few things that can go wrong during a clutch install. Very unlikely. I have a similar clutch. They (ACS) make good gear. No, it is not normal. It is possible that you just need to bleed the clutch slave. But the new clutch will also have a more aggressive actuation force/pressure, and so your old slave cylinder might be a bit leaky or otherwise compromised, and not up to the extra force required. Or the master cylinder, same.
    • Hi...so a "development" here aswell The swap is "done" and car went "test drive" BUT it seems the clutch(maybe gearbox?) is a little bit sad? I bought this clutch kit https://justjap.com/products/xtreme-heavy-duty-organic-clutch-flywheel-kit-nissan-skyline-r31-r32-r33-push-type "Problem" is that the first gear is hard to put into and it seems that the clutch is not disengaged. It was not the problem with the old clutch...(or like sometime the first gear would not get as easy specialy when the fluid was cold) So? Can it be like...bad "install" or is the clutch wrong ((it should not have been) i done research to get the right one) Or is this "normal" with new clutch and needs to be break in?
