ok well today I refurbished a BOV, dismantled the whole thing, checked for damage, cleaned, polished and greased the spring etc, and I noticed how simple BOVs are,
so I was just wondering if anyone had attempted or made their own BOV?, seems like they could be made fairly easy, with a lathe and a few welds, and it wouldn't be too hard for a good quality job.
cheers
https://www.sau.com.au/forums/topic/111336-has-anyone-built-their-own-bov/
A guy I went to school with made one in yr 12.. Looked the goods. Said he tested it on an air compressor and it worked... If you can get the spring rate right and used the right metal I spose it could be done effectively. There are work shops out there that will make you a custom one as well.
why bother?
is ther esomething worng with the stocker?
or GTR ones you can buy for $150 for the pair?
or the cheapo aftermarket ones which would be made just like the one you plan on making?
just seems like a waste of time, effort, money, time.
Oath to that..
yeah all those reasons, its very satisfying to make things yourself.
I didnt say I was going to but for instance, if you needed a good quality bov suitable for holding big psi, and you didnt have the money, it could be an option, looks like around $15-20 worth of metal and parts, and about 2-3hrs work if you had access to a workshop.
oh and alot of cars dont come with BOVs and alot of the ones that do arent good for high boost.
Edited by midnight
My old man and I made 2 or 3, which i used on my ET Pulsar and at the very begining of owning my Skyline.
They are very simple to make if you have a lathe which my old man does and some Aluminium.
The spring rate is hard to get right but its a matter of trial an error.
I then bought a HKS one and started having issues, this was when i realised Atmo BOV are hard to tune right, so i now run the Std plumbed back ....
ok.
however, I question why someone who needs to "hold big psi" doesn't have $200 for a bov.
this "big psi" is obviously not comming fro the stock turbo, so you would have spent about $2K on a turbo.
about another $2K for supporting mods for fuel and clutch and so forth.
intercooler, wastegate, possibly a full rebuild with forged bits etc...
I don't think another $200 for a bov from say GFB is going to break the bank...
But if by big PSI you are talking about 1 bar from stock turbo, don't worry.. the stocker can handle it.
if you are talking big psi like 30 psi making something over 600rwkw from a 2jzgte or rb26, then don't worry, the stock pair of $150 GTR bovs handles that too.
The Stock SR20 bov from S14-15 has been tested with 100psi on both sides of the piston (just like when you are on boost) and it doesn't leak.
of course releasing 100 psi might be an issue for the piston and opening of th ebov but that's a different story..
point is, making a bov maybe satisfying, but in the end it's useless when a stocker can be had for same price or less, and work better.
I think that the guy that made the $22 boost controller.... he made something usefull.
even when they were being sold for $22, he was still making a tiny profit and it was a device that works very well and was needed and useful.
anyway, my view only.
i made one years ago.....i also made a few wastegate's...i like making my own stuff.....and you know what.....I really dont care if it ends up costing me double on what i can buy one for....some of the best,neatest parts i have seen have been made by the owners themselves
GTST, my car did not come with a bov, and at the end of the day $20 of materials is still cheaper than $200 for a GFB or $400 for a trust type R.
and what about if you were a machinist or mechanic on an apprentice wage?
I myself bought a secondhand professor sheepdog BOV quite cheap, I stripped it down and completely refurbished it and am planning on modifing it for plumbback, so it looks like ill be in a workshop anyway.
but yeah the point of the thread was to see if people had built their own, and judging by the replys, a few people have and have come up with decent results, take ylwgtr2, who built a bov and a wastegate, a good quality wastegate costs quite abit.
When I was in highschool I used to spend most of my electronics class on the lathe, making up useless crap that I did not need, but I enjoyed being able to think up something, and have the ability to actually create it.
so yeah if I'm ever in a workshop with time to kill, i'll probably make one.
Edited by midnight
wow that's going to release a lot of pressure in a hurry looking at those vents.
Looks really nice and simple.
I would love to make my own but i don't have a lathe. :teehee:
I wouldn't care if it cost me $200 to make one i love making my own stuff...
I have done all my own mods on all my own cars. Big ups for all those that have made their own...
    • Yeah I've had too many issues with knock off's on the BMW's. I don't want to do a job twice or more because the parts are shit.
    • I read this and thought "ah! I will do this scissor jack on the tow point thing!" I just use my floor/low profile/costco jack and lift the car up by the tow hook itself, then slide jack stands under. Never thought about using scissor into floor jack combo :p
    • Well, my new WMI system took much longer to finalize. I actually missed my dyno appointment last Friday and lost my 150$ deposit. I'll be going back in the next week or two.  To sum it up. I only kept the AEM tank from my old setup. I replaced the AEM pump with a higher flow/pressure ProMeth 30GPH pump. I also swapped over to a 6AN low pressure feed line to the pump from the tank. There's also a pressure switch you cannot see on the pump high pressure line.    This is feeding 6x 200CC direct port nozzles and 1x 500CC Pre Throttle body nozzle. All fittings are Swagelok, because well why not. I also have a 300PSI pressure sensor up front.    I now have my Haltech ECU controlling everything. I start my pump with a basic relay at 5PSI and deadhead it. I then PWM a 3000CC methanol Injector to control flow starting around 10psi. The pressure switch in the trunk, along with my tank level are safeties before I ever get to 10PSI, and then I use my pressure sensor upfront as a secondary safety to cut the WMI and corrections in case the injector blocks or a line ruptures.  Wish me luck on the dyno!
    • So, I'm back with bad news. There's no jack long enough on this planet that will reach the front subframe. If by some chance there is, it would weigh 200lb's.  I purchased a long reach jack... The damn thing weighted 120lb's and was massive. Didn't even come close, was still short at least a foot. It was a pain, but I brought it back. Next I decided HA! No problem, I'll get an Extra long reach jack. Well, I couldn't lift the box... It must have weighed 160LB's and luckily there was an open box in store. I took measurement and was still nowhere close.  Sadly I've lost hope and have accepted defeat.
    • Thanks for that tip, niZmO_Man. I think the battery is OK. It's quite a new one, but I'll check. Last time I needed a new battery, everything electronic was fine, except that there wasn't enough current to turn over the starter. I decided to order one of the partial AV system translation CDs from Car Audio Workshop in NZ. That might have some effect, or help me diagnose the date problem. 🤞
