i am in the proccess of planning to rebuild my engine at the moment, and heard that there's a problem the R32's RB26 oiling system, and my build is aiming the 600-650hp range and i can't afford a NEW crank and they are like 300 000yen +
my question is, will stock rb26 crank support this hp range and be safe ?
what can i do to the stock crank to make it better ?
if i decide to buy a new crank what do you reccormend for CHEAP/Strong crank set up
i will be running N1 water pump so anything that compatible with that will be good
thanks
https://www.sau.com.au/forums/topic/111793-bnr32-rb26-crank/
Speak with Greg at Pro Engines in Queanbeyan near Canberra - 62995211. He has the answers to your Q's and the solution he may even pick up on this thread and answer directly.
http://www.proengines.com.au/
Edited by Sinista32
thanks
You can buy a brand new R33 GTR crank for around $1000 but there is a length lead time out of Japan at the moment.
This is one of the most common upgrades for an R32 GTR engine build
thanks
I wouldn't be running an N1 water pump on a road car. They are designed to avoid cavitiation as sustained high rpm (as in circuit racing). Not a good idea on high power road car.
There are plenty of problems in RB oiling systems, I strongly suggest you do a search ("Sydneykid" and "+oil+restrictors")
Fitting a wide oil pump drive flange collar to the R32 crank is a good idea, for more details do a search ("Sydneykid" and "+adaptor+collar")
:sweat: cheers :(
:P cheers :sleep:
hey sydneykid just off topic abit but my rb26 running an n1 water pump and it never ever gets over 1/2 on the temp gauge even after an hour on the dyno, though only light tune to 4000rpm, well see on the proper tune. what point rpm range does it not work correctly? low rpm i'd imagine? i know the blades inside are huge in comparision to my stock old pump.
thanks
Brad
thanks
Brad
Hi Brad, they work great at 4,000 rpm, but they don't work so good at idle, in traffice with the aircon on for a 40 degree day. They simply don't move enough water at low rpm. That's so they don't get cavitation at high rpm. Lots of guys forget what "N1" really means, that is quite specifically designed for circuit racing, sustained high rpm for hours. What N1 doesn't mean is "better than standard in all conditions".
An example, I had a guy chasing a water temp problem in his Targa GTR while driving/idling between events. Tried a low temp thermostat, all that meant was it wouldn't warm up for ages on cold days. It ran rich as, because the ECU thought it was still cold and fouled plugs. He then threw a PWR 50mm radiator at it, still ran hot engine temperatures. He cheaked the head gasket, swappped sensors and gauges, spent heaps and the problem was still there. In desperation he rang me and I asked the obvious question" N1 water pump?". The answer was "yes" so I suggested trying a standard R33GTR water pump. I took me a week to convince him to at least try it. Bingo, no more engine water temp problems.
:P cheers :sleep:
Edited by Sydneykid
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
