I noticed a few people showing interest in helmets for track and drag events, so I thought I'd organise a discount rate from Sydney City Motorcycles for SAU club members. They have a big range there, and prices are very reasonable.
The helmet that he recommended was $120, and he said that he could do it for a price of $99 for members.
If there is a different style that you would like (other than the recommended one), the guy said that he will do you a good price (about 10 to 15% off any helmet depending on the style).
I have set up an account with them, which has details on the discount rate. The account number to quote is #16892, and the account name is "Skylines Australia Motor Club". The salesperson to talk to regarding the offer is Andrew Cura.
Please note, you need to be an SAU member to take advantage of the offer. This means that your membership card needs to be displayed when purchasing in order to be eligible for the discount.
This isn't restricted to helmets either, if you want anything else from SCM, the discount will apply (eg. gloves, suits etc).
Cheers guys! :P
1a Epping Rd
Lane Cove NSW 2066
(02) 9418-3000
https://www.sau.com.au/forums/topic/111933-motorsport-helmets/
so this is no good for members outside of NSW ay...unless we want to drive to NSW of course
Well you could still fax your card to them and buy over the phone with a credit card if you knew the style/size/model that you wanted? They didnt mention it being restricted to NSW members only.
Check out their website, and see what brands they carry, then check out stores local to you and pick one..
Keep in mind the discount would probably be less than the cost of shipping though.
This is the big one on the corner of Centenial & Epping Rd ya??!!
If so I am there like a fly to a turd!!! $99 BOYAH....just gotta wait for my membership card and i can get my helmet!
Yep, thats the one!
Like Kennedy said....all helmets and heads are different shapes. Some are even prettier than others.
Go there and try them on you will feel the difference in different brands, ignore the label and buy the confortable one :)
Great work Primodral D:
...we have membersihp cards? if so then i haven't received mine yet :D
Hey Guys,
I bought one of these things on Thursday night and it's great value. The service there is great and the range is one of the largest in Sydney.
I bought a MDS R series for $100.00 which I think are awesome while MDS may be one of the the cheapr ones, but they are a subsiduary of AGV (it even still had the AGV branding on the indside) and it had a great fit. I managed to get a free bag out of the deal aswell.
I was a little suprised that I was the first person to actually take advantage of this group buy (according to them) considering there was all of this "Track Talk" buzz floating around. Cmon guys, get yourself a helmet and get your asse on da track!!!!
Moot
Hey Guys,
Moot
i also saw them about 2 weeks ago and they chopped a little off the price when i mentioned the SAU group buy(but not much!).. got one of those AGVs, heaps happy with it!
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
