i have a ticking noise coming from something in the engine bay.
sounds like its coming from the passenger side of the car towards the front of the engine.
its louder on start up but gets a bit softer after a 10 seconds of running but i can still hear it.
any idea's before i take it to someone to get looked at end up paying for things i dont need?
thanks
ash
https://www.sau.com.au/forums/topic/112010-i-have-a-ticking-noise-help-please/
Cold or Warm starts?
Could be the lifters just getting their first sqiurt of oil for the day.
Alternativly, the stock injectors are pretty damn loud on RB's?
Could also even be the fan hitting against a pipe (in my case FMIC) or wire thats loose?
Has your timing belt been changed; or alternaviely how many (genuine) kms has the car done?
btw:- bring it out on the next sthn SA crusie!
Edited by Tangles
i had a similar noise with my series2 not long after a long trip recently so got the belts all done on the front including the timing belt just to be sure and noises all gone now, all the drive belts were cracked an mechanic said it sometimes happens cos of the chemicals they spray the cars with when they de-bug them for quarantine?.
must react with the rubber i spose.
timing belt was done very recently
its on both warm and cold starts
fan clears the cooler pipe... just :D
i took it to my local mechanic today and he thinks its the exhaust manifold gasket. sound right to you guys?
"Just"
Theres your issue
Paint some black paint on your pipe, then start it and see if it rubs any of the black paint off.
I know because my pipes are painted black and the paint gets taken off. Put some sandpaper there to wear it down.
no it isnt that.
it clears. that was the first thing i thought it was.
there is a 5 mm gap
ive grabbed the pipe and pulled it up away from the fan and its still there. ive also pushed the pipe down and it still doesnt quite touch the fan, its braced quite solid.
I'll be doing the same when i get my turbo high flowed, i had a nut missing off my exhaust manifold, Doesn't seem to be leaking but will pull it all off and replace the gasket just to be sure.
  • 3 weeks later...
I head a similiar noise that begun just after I had my cat off and on. I hunted it down to 3 nuts and studs missing from my exhaust manifold! I dunno where they went, car is an unmodified import. I guess the stress on manifold of me playing around with cat made it start to leak.
Why are other peoples exahust manifolds missing bolts too? Seems odd to me. Suppose I'll have to pull it to bits now!
what oxford1327 said interests me, ie the chemicals sprayed on to decontaminate the car. As mentioned in "electronic rust prevention" the undersides of my S1 ar veiled in a film of rust (corrosion). Especially the bits that were cad plated.Apart from having a flat battery yesterday this rust is the only thing that isses me off.
Its going to cost $640 at Endrust to get it fixed.
Odd - mine is completely rust free underneath - pefect! Nor have I found any ceramic bits as yet... as yet!
I've got the same noise in my series 1. Stock injectors are noisey. Seems to be a nissan thing, the ones in my sr20 wern't much quieter. But i have also noticed that the boost control solernoid is also a bit noisey.
There are pollution control solenoids which ticker away - best solution is to rubber mount them. However these are at the back of the motor and not the front, so I could be sending you on a rabbit hunt.
  • 1 month later...
Though not a Stagea Tick, but still Nissan.
Gave the S13 an oil change and this time changed the filter and changed the plugs. Put in the required amount
of oiland on start up a diabolical tick. More like an elf with a sledge hammer. The boys thought some foreign body got in thru a plug hhole, etc etc etc. Every time it started, tick,tick wtf.
The oil light didn't come on an the ECU was checked. Nope.
In desperation I put a bottle of Nulon in. The effin tick Stopped. Why.
My thought is that somehow the oil pump got an air lock and maybe the extra bit of lubricant helped it pick up properly. I have never experianced any5thing like this in 50yrs of oil changing, and we have changed the S13 and 180sx drifters many times before with no probs.
After the noise went away, the car was taken for a thrash up toBrissie and the next day was flogged a bit at
Queensland Raceway.Runs sweet as a nut.
Has anybody experienced this type of problem? The guys on Sil had no ideas.
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
