Intake temp cooling options.
45 members have voted
You do not have permission to vote in this poll, or see the poll results. Please sign in or register to vote in this poll.
Hey Fellow Wagoneers,
I am interested in knowing what people think of different styles of intercoolers. I only recently found out that PWR have bought out a "barrel" style, duel pass, water to air intercooler that you can fit between your standard intercooler & the T/B. The full setup (intercooler, pump, radiator, & plumbing) costs about the same as a decent sized Air to Air installed, but has a lot more stelth & from what I've read, alot more efficiant.
Before everyone directs me to the search button & gives me instructions on it's use, I have used it.
What i'm after is your opinion &/or ideas on how we can further cool intake temps.
Regards,
Jeff
https://www.sau.com.au/forums/topic/112452-intake-temp-cooling-options/
the only reason you'd go for a water-air intercooler is when there's no room for an air-air. they're more efficient as the energy only has to transfer one medium, not two (water to air still has a radiator making it from air - water - air)
i am also looking at fitting a water to air cooler and have looked at several options but the water to air option seems to be the way i will go as it is more discreet as well as being a bit more efficient, i will however watch this thread for updates and also opinions
Value for money an air-air cooling will be best.
I mean, youll get a bit less response, but if you can feel it when driving, you are not driving hard enough, or high enough in the rev range.
Went for a drive last night and after stopping to let everything cool down, my GTR cooler was hot to touch on one side and very cold on the other. I mean, how much more cooling could you possibly want.
To the best of my knowledge, apart from times when air-air's dont fit, the use of a air-water-air cooler is for drag racing when you want to have instant cold intake temps off the line.
Mate, if you want to go all out, get a big box of dry ice, run about a metre of pipe through that box, and theres your cooler. Air will be ice cold when it exists.
only reason other than being discreet for fitting a water to air type is that you wont have to butcher the front of the car to fit it in there! and you also have less pipework to stuff in the bay.
It's all about your power target and what you use the car for. What is good intercooling for a 200 4wkw daily driver is not good intercooling for a 600 4wkw drag car.
Until I have some idea of the power target and the intended usage pattern I don't think I can respond to the question.
;) cheers :O
PS, I don't believe a W2A intercooler system (water pump, controller, stainless steel barrel, water pipes, modified inlet pipe work and a heat exchanger in front of the radiator) is any more stealth than a return style, A2A FMIC painted black.
in alot of ways i agree with you sydneykid but i am yet to find any one that has fitted an A2A to a series2 without butchering it? if i were to fit an A2A it would be painted matt black but am still looking at the W2A options too.
if you know of anyone who has done a series2 fit out i would be keen to see pics or get details of which kit? as all the ones i have seen in the forums have beeen on series1 stags
Well, I'm going to fit an intercooler water spray this weekend that i'm making from a corrolla wash bottle($10 from wreakers, a couple of garden watering system mist nozzles $2 each & a switch i had in the garage, about $5).
I'll get some pics & a how to incase anyone else wants to have a go.
Should be interesting to see how it goes.
  • 5 months later...
How did it go?
How did it go?
Haha 6 months down the track, dig it up, I like it, nice work Hugh!
How did it go, you could hook up some type of thermal switch that was also linked to rpm that would switch it on when required too... If it was effective?
Luke
I dont see any real benefit to lower intake temps beyond the std air boxs affect.
If I was serious about it, id get a hole saw, cut a hole where the stock SMIC pipe goes and run a pod to where the stock SMIC sits, otherwise I wouldnt really bother.
I personally cant see a water spray kit being that effective... unless, you sprayed liquid nitrogen or submerged the intercooler in a box of dry ice.
Infact, I think its 1hp for each 1 degree centigrade or something and a water spray kit wont bring the temperature down beyond ambient either. So lets say a decent FMIC which is probaly 10 degrees above ambient... so much effort, so little return.
How did it go?
I couldn't get a good enough one way valve for the right price so the water in the resovour would just siphon out after it was activated. I tried to move the tank lower, but still could not get it low enough for the standard smic
So what other cooling effect is it, when you see a water bag hanging off the bullbar of some old cockies ute? The water is always suprisingly cold, & all from evaporation. You think that the subie wrx sti had a IC water spray as just a gimick?
Sorry, just a bit of rambling.....
Just my opinion.
Regards,
Jeff
One way antisiphon valve, buy one from your local aquarium retailer.
Mix 70/30 water and metho. Guaranteed to lower the intercooler fins to 15 degrees BELOW ambient at anything over 60 kph.
Don’t believe me?
Try it on your hand
Blow on a dry hand
Then wet it with water and blow again
Notice the temperature drop?
Try it with 70/30, notice even more temperature drop?
:P cheers :P
PS; EVO’s have intercooler sprays standard
Edited by Sydneykid
Nice,
I have felt that cooling metho effect before (cleaning windows) takes me back...
So it could drop the temp below ambient, very much worth it on a 30ºC + day, I thought there was something in this, just wasn't sure! Thanks SK.
Cheers
Luke
As most people, ive felt the cooling effect of metho/acetone/paint stripper before but can someone shed some lights on this from a physics point of view.
Ive got an understanding of the idea of boiling temps, latent heats etc, but someone explain to me why water has a higher latent heat of vaporization (therefore should "suck" more energy) but metho feels colder?
Substance Specific latent heat of fusion
kJ.kg-1 ºC Specific latent heat of vaporization
kJ.kg-1 ºC
Water 334 0 2258 100
Ethanol 109 -114 838 78
Ethanoic acid 192 17 395 118
Chloroform 74 -64 254 62
Mercury 11 -39 294 357
Sulphur 54 115 1406 445
Hydrogen 60 -259 449 -253
Oxygen 14 -219 213 -183
Nitrogen 25 -210 199 -196
Do you want to be using something that has a low latent heat and low boiling temperature, so it is more effective in evaporating and drawing energy out. I guess, ideally, something that has a good ratio of latent heat and boiling temp, hence being able to "suck" the most "heat" out with the least temperature change?
As far as WRX's and waterspray, well, the cooler sits on top of a hot engine block, so i am sure they wanted to do as much as they could to help the cooling without going FMIC (lag)
BTW, ARE make a kick ass dry ice to air intercooler, but obviously you need to refill that. Also on mythbusters they made this awesome copper coil in a bucket of dry ice that froze beer before it got down to teh bottom of the coil.
Anyway, cheers
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
