I have been having alot of problems with the bolts on my engin.
first i had problems with just a normal bolt that was very warn down. And now i have a little screw that u have to use an allan key to loosen but it seems to be very warn and engine screws and bolts tend to be very tight.
if anyone has any suggestions or tips i would greatly appreciate it.
Thanks .
https://www.sau.com.au/forums/topic/112484-need-someone-with-skills/
I had a friend that stripped his sump bolt (commodore of course). Best thing to get it off with was a pair of vice grips.
As for the allan key, maybe use a hammer to bash the next size into it, but you will want to replace them asap. dont put them back in.
Crimpage.
well if you are having trouble you need good quality spanners and to hold them nice and straight to the bolt. Some chinese spanners aren't as exact as they should be. For really troublesome bolts you want a socket that has only 6 sides (most have 12 and some are deliberably rounded).
but just be careful if it is relly tight and you round if off you are in a heap of trouble, you will have to drill the bolt out, weld a new nut on the end or some other dodgy fix.
My socket set is repco. but the thing is the person befor me had warn down a few screws. but i didnt know about the 6 sided socket thanks.
i will try vice grips, or a bigget size and making it fit
but its in a little stuffed up place so i dont know about vice scripts.
but the info use gave should help heaps.. ill get back to u on that.
It all really deends on what type of bolt it is/how its placed and so on. If its in a tight place you are in a world of trouble. A technique i have found that works when all else fails is to use a sall cutting piece on a die grinder and cut the head of the bold so u can put some sort of flat blade crewdriver bit in there. The easiest way is what already been said. Band a bigger allen key in or bank a socket over. Either way if you are in a tight spot that could be difficult.
Make sure you use an extender, and proper 1/2" shifter which gives you more leverage. The better the equipment, the more stubborn bolts you can remove without stuffing them.
Make sure you use the correct socket too, there are a few weird imperial bolts you will find around.. commonly 1/2" heads.. which are about halfway between 12mm and 13mm. Using a 13mm will generally strip them, but a proper 1/2" will get them off.
yeah, get a half inch drive socket and a big f**k off ratchet
if not that a rattle gun will solve all problems :)
as for the worn down allen key screw, if you can get to the side of it just use pliers- doesnt matter if you f**k it, just as long as it comes out
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
