Got a question for the professional tuners out there...
In light of our expected fuel price increase to a minumum of $1.40/litre for unleaded and probably up to $1.55-$1.60 for BP ultimate over the easter break i'm going to make sure my car has the best possible low speed economy tune in it.
So... this brings me to how lean can you go....
For when the car is cruising at speeds of 60-110k's under light load, as in not accelerating it should be possible to run the car considerably leaner than the 14.7:1 AFR that the catalytic converter functions best at. To be honest, emmissions be dammed! I want to maximize my fuel economy to the limit of what my RB20DET can do.
From research i've done in this area with other makes of car, Saab for example can run as high as 17:1 at 120km/h without any engine damage, and get 7lt/100km economy.
Does anyone have any real tuning experience as to how lean you can take an RB engine under light load conditions while it still being safe? I was thinking 15.5 should be possable at least...
Cheers,
Ian
  • Replies 48
Posted Images
I think you'll find that bad emissions come from the engine running too rich.
I personally would not run the engine to lean as partial throttle is typically the mostly likely time the car will ping as most tuners spend more time refining the flat out map rather than the partial throttle map.
Saying all this... when you say tune the car I presume you are putting a power fc in?
I would talk to someone you feel comfortable tuning your car and talk to them about running it very lean in partial throttle. I think you'll find they are hesitant to do it because if it blows its there creditability on the line.
Its also good to keep things in perspective when worrying about fuel consumption. Say that you run it lean and reduce fuel economy by 3litres/100km which I think is optimistic by the way. Say you do 300km a week. That is 9 litres more that you would have used with a tune that is perfect for the engine. That is no more than $15 a week. You can't surely tell me that is going to kill your bank account.
On another note, if you put a powerfc in, your fuel economy will improve anyway as the stock ecu runs the engine very rich.
Hope that helps.
Edited by nfi
i have done it on my own car with powerfc + wideband and got some kick ass results. i leaned mine out quiet a lot, a bit past 15 on low load at 100km/h and fairly lean below 100 in low load / light areas.
i would suggest reading http://www.skylinesaustralia.com/forums/in...9377&hl=powerfc
most of the stuff you need to know is covered there (the last 3 or 4 pages)
Sorry I should have provided a little more info so here's it all....
The car runs a wolf 4 plus with MSD DIS4, 3 coil waste spark, 044 pump, 460cc injectors, stock plenum, front mount IC, high mount manifold, GT28 BB 400 with a 0.64 turbine an d 0.7 compressor. The car is a GTS4 with GTR manual gearbox. Diffs are stock i believe.
I do all my own tuning. Yes running rich makes for the worst emmissions as "NFI" said, but a catalytic convertor works most efficently at the afr of 14.7:1 and efficency decreases as you go leaner from there. As I understand it, although CO levels fall with a leaner burn AFR, other emmissions rise. I'm gussing SO2? Who knows...
I use a PLX devices wideband system to get my mixtures correct. Thus far i've tuned to 16lb boost and have 11.5:1 afr at that boost level. I'll be increasing that to about 20-22lb maximum when I get my new plenum. At 0 boost but full load i've leaned it back to 14.2:1. Peak power at this point is supposed to be made at 13.8:1, but this is my economy map... sort of. If I want power I rev it, make boost and its into 12:1-11.5:1 AFR territory.
At present its around the 14.7:1 at light loads at 100k's in 5th. Incidently thats about -10 in-hg on the boost gauge. As the Wolf ecu uses a MAP sensor not a MAF, I can easily identify that load point and tune that afr accordingly.
As suggested by paulr33 and Busky2k 15-15.5:1 is about what is considered fairly safe too. I don't have a EGT sensor though which is a shame because it would be extremely useful!
One other variable is that Paul's got an R33 which is a 9:1 CR engine if i'm not mistaken, and the RB20's are lower at 8.5:1 CR. The higher CR will allow a leaner burn due to better fuel/air squish, while maintaining a lower EGT in comparison to the same AFR on a lower compression RB20... in theory that is...
Thats my problem... lean tuning is mostly theory for me at the moment as i've read a fair bit but have yet to come accross a good tuner with real answers and RB experience.... I asked the question of one of the guys at Sub Zero today and he was going to ask a few other tuners and get a concensis for diferent RB engines. I'll let you know how that goes...
Fact is, 99% of tuning is all done for that top end power figure, which is a little odd becuase when you think about it, thats about where 1% of your actual driving is done.... So long as it drives in traffic, doesn't over heat and makes a shitload of top end HP, is aparenty all the average skyline owner wants. :S Or at least what the tuners tune for...
Everyone feel free to jump in and correct me here...
Cheers,
Ian.
So true. People get wrapped up in the top end number after a tune and forget about how the car actually *drives*. I've spend considerable amount of time in the first 10x8 cells on my PowerFC as thats where 95% of the driving occurs and I've tweaked the AFRs smack on 14.7 with readouts using my Innovate Motorsport LM-1 Wideband. This is because the PowerFC can then take care of any small variances as time goes by via its closed loop system and keep it at 14.7:1. I could go leaner again but any leaner than 15.5:1 and the car starts to misfire a bit. The fuel economy now is good enough for me anyway.
I have yet to tackle the low rpm/load low ignition map. I believe by relying on the stock knock sensor to find the MBT is the wrong way to go about it.
the stock ecu (and powerfc) have closed loop which will make it aim for 14.7 on crusing for the ideal economy and emissions. i found with this style setup i was getting average ish economy usually 350ks on the street and 500 on highway. tuning with closed loop still on in the powerfc just meant the results were juggled a bit in real time. it was only when i turned off closed loop and tuned it myself that i got 400+ on street and 600+ on the highway.
so closed loop certainly isnt the be all and end all but certainly a good start. plus its a lot of work to tune all the fuel map cells as you need to make sure the afr's in the low cruise areas's are safe and not too lean.
turning off closed loop in the FC and driving around its a bit too lean in some spots
Not meaning to be a smart arse but... $15x52weeks = $780.00. But having said that I find most people use a tank a week. So with a good tune thats 500-600kms a tank (which is what I am getting) So thats closer to 18L (basing it on your estimation) which brings it out to $1560.00 a year saved. Sure as shit I could find a better way to spend that money than on fuel. Thats about 3 weeks wages for me, that would hurt. Just thought I would point that out. Also add this in to buying your fuel on the wrong day... then its even more.
My understanding is that at 14.7:1 EGT's peak at their highest, below or above this the egt's drop.
Maximum economy really depends on the motor its self, lean it until drivability suffers.
As SK said to me... Lean it out under load, use the injector pump settings to gain throttle response.
Many of the RX7 blokes lean out their rotors (which are damaged by lean afr's easier than piston motors) to around 14:1 with a psi or 2 of boost. They then for example drop to 13.5:1 up to 5-6psi then 13 to maybe 9 then maybe 11-12:1 under 9-10+
It really depends on how the RB handles the lean conditions under 0 vacuum. If it bucks and is obviously not liking it richen it up until it no longer.. Maybe it can handle leaner.. who knows, no one really shares their information too much but I do plan to find out. :starwars:
With the FCTune's auto tune function soon to be released I am hoping to get my hands on a wideband so I can do a little street tuning.
My current tune runs 14.7 during closed loop then drops to 13.5 (forget the vacuum) then 13:1 under 0 vacuum.
I run my car lean as hell when i drive to work and back.
In the PFC setting ING/IGN i turn the number 1.000 down to 0.769 which is about 24% leaner then the standard map.
This figure is good when driving on the freeway and it does run a bit shitty around town but it is very driveable. I can save about 3 - 5 litres on my day trip to work and back which is 120km each day.
For $20 worth of fuel I get about 15 litres if i lean it right out and crooze at no more then 110 120 I have around 3 - 5 litres left over from my 120km trip. Not bad for a car with 740cc nismo injectors and 350 rwhp.
The downside to this method is that if come past a commodore on the freeway I cant hit it beside him and if you forget you have taken 25% fuel out of the map and you give it a good hit.. You can be walking very quickly :starwars: so yeah its not that hard to go back in and put it back up to 1.000 if you got a good 20 seconds.
So yeah something I have wondered about is does an engine run better lean with more timing advance or with retarded timing ???
I used to put in a extra +5 deg timing in overall but stopped doing it and have not noticed any difference.
I believe the leaner on crooze the better. My turbo is top mounted to the extra heat would wash off pretty quickly and i do keep my eye out on knock levels heaps.
I DO have a question on this topic actually.
IF I am running the PFC with 24% less fuel WITH Closed loop mode still on. Would the PFC still correct it back up to 14.7 or be trying to ??
If thats the case then I will try and turn closed loop off because my car can run at about 16:1 17:1 without whinging too much about it as I had my friends Autronic Wideband sensor in my car for a few months when I tuned my car myself and it was running fine.
So yeah. I might try this on the way home and see how it goes.
yes with 02 feedback on it will always try and aim for default ideal afr. which can be set by datalogit also. if you drive around with 02 feedback off the afr's wont auto dial back to 14.7
Hmmmmmm... I am going to turn off closed loop mode on the way home and see how it goes... its a 60km trip.
    • Any update on this one? did you manage to get it fixed?    i'm having the same issue with my r34 and i believe its to do with the smart entry (keyless) control module but cant be sure without forking out to get a replacement
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if something was binding the shaft from rotating properly. I got absolutely no voltage reading out of the sensor no matter how fast I turned the shaft. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • So this being my first contribution to the SAU forums, I'd like to present and show how I had to solve probably one of the most annoying fixes on any car I've owned: replacing a speedometer (or "speedo") sensor on my newly acquired Series 1 Stagea 260RS Autech Version. I'm simply documenting how I went about to fix this issue, and as I understand it is relatively rare to happen to this generation of cars, it is a gigantic PITA so I hope this helps serve as reference to anyone else who may encounter this issue. NOTE: Although I say this is meant for the 260RS, because the gearbox/drivetrain is shared with the R33 GTR with the 5-speed manual, the application should be exactly the same. Background So after driving my new-to-me Stagea for about 1500km, one night while driving home the speedometer and odometer suddenly stopped working. No clunking noise, no indication something was broken, the speedometer would just stop reading anything and the odometer stopped going up. This is a huge worry for me, because my car is relatively low mileage (only 45k km when purchased) so although I plan to own the car for a long time, a mismatched odometer reading would be hugely detrimental to resale should the day come to sell the car. Thankfully this only occurred a mile or two from home so it wasn't extremely significant. Also, the OCD part of me would be extremely irked if the numbers that showed on my dash doesn't match the actual ageing of the car. Diagnosing I had been in communication with the well renown GTR shop in the USA, U.P.garage up near University Point in Washington state. After some back and forth they said it could be one of two things: 1) The speedometer sensor that goes into the transfer case is broken 2) The actual cluster has a component that went kaput. They said this is common in older Nissan gauge clusters and that would indicate a rebuild is necessary. As I tried to figure out if it was problem #1, I resolved problem #2 by sending my cluster over to Relentless Motorsports in Dallas, TX, whom is local to me and does cluster and ECU rebuilds. He is a one man operation who meticulously replaces every chip, resistor, capacitor, and electronic component on the PCB's on a wide variety of classic and modern cars. His specialty is Lexus and Toyota, but he came highly recommended by Erik of U.P.garage since he does the rebuilds for them on GTR clusters.  For those that don't know, on R32 and R33 GTR gearboxes, the speedometer sensor is mounted in the transfer case and is purely an analog mini "generator" (opposite of an alternator essentially). Based on the speed the sensor spins it generates an AC sine wave voltage up to 5V, and sends that via two wires up to the cluster which then interprets it via the speedometer dial. The signal does NOT go to the ECU first, the wiring goes to the cluster first then the ECU after (or so I'm told).  Problems/Roadblocks I first removed the part from the car on the underside of the transfer case (drain your transfer case fluid/ATF first, guess who found out that the hard way?), and noted the transfer case fluid was EXTREMELY black, most likely never changed on my car. When attempting to turn the gears it felt extremely gritty, as if shttps://imgur.com/6TQCG3xomething was binding the shaft from rotating properly. After having to reflow the solder on my AFM sensors based on another SAU guide here, I attempted to disassemble the silicone seal on the back of the sensor to see what happened inside the sensor; turns out, it basically disintegrated itself. Wonderful. Not only had the electrical components destroyed themselves, the magnetic portion on what I thought was on the shaft also chipped and was broken. Solution So solution: find a spare part right? Wrong. Nissan has long discontinued the proper sensor part number 32702-21U19, and it is no longer obtainable either through Nissan NSA or Nissan Japan. I was SOL without proper speed or mileage readings unless I figured out a way to replace this sensor. After tons of Googling and searching on SAU, I found that there IS however a sensor that looks almost exactly like the R33/260RS one: a sensor meant for the R33/R34 GTT and GTS-T with the 5 speed manual. The part number was 25010-21U00, and the body, plug, and shaft all looked exactly the same. The gear was different at the end, but knowing the sensor's gear is held on with a circlip, I figured I could just order the part and swap the gears. Cue me ordering a new part from JustJap down in Kirrawee, NSW, then waiting almost 3 weeks for shipping and customs clearing. The part finally arrives and what did I find? The freaking shaft lengths don't match. $&%* I discussed with Erik how to proceed, and figuring that I basically destroyed the sensor trying to get the shaft out of the damaged sensor from my car. we deemed it too dangerous to try and attempt to swap shafts to the correct length. I had to find a local CNC machinist to help me cut and notch down the shaft. After tons of frantic calling on a Friday afternoon, I managed to get hold of someone and he said he'd be able to do it over half a week. I sent him photos and had him take measurements to match not only the correct length and notch fitment, but also a groove to machine out to hold the retentive circlip. And the end result? *chef's kiss* Perfect. Since I didn't have pliers with me when I picked up the items, I tested the old gear and circlip on. Perfect fit. After that it was simply swapping out the plug bracket to the new sensor, mount it on the transfer case, refill with ATF/Nissan Matic Fluid D, then test out function. Thankfully with the rebuilt cluster and the new sensor, both the speedometer and odometer and now working properly!   And there you have it. About 5-6 weeks of headaches wrapped up in a 15 minute photo essay. As I was told it is rare for sensors of this generation to die so dramatically, but you never know what could go wrong with a 25+ year old car. I HOPE that no one else has to go through this problem like I did, so with my take on a solution I hope it helps others who may encounter this issue in the future. For the TL;DR: 1) Sensor breaks. 2) Find a replacement GTT/GTS-T sensor. 3) Find a CNC machinist to have you cut it down to proper specs. 4) Reinstall then pray to the JDM gods.   Hope this guide/story helps anyone else encountering this problem!
    • perhaps i should have mentioned, I plugged the unit in before i handed over to the electronics repair shop to see what damaged had been caused and the unit worked (ac controls, rear demister etc) bar the lights behind the lcd. i would assume that the diode was only to control lighting and didnt harm anything else i got the unit back from the electronics repair shop and all is well (to a point). The lights are back on and ac controls are working. im still paranoid as i beleive the repairer just put in any zener diode he could find and admitted asking chatgpt if its compatible   i do however have another issue... sometimes when i turn the ignition on, the climate control unit now goes through a diagnostics procedure which normally occurs when you disconnect and reconnect but this may be due to the below   to top everything off, and feel free to shoot me as im just about to do it myself anyway, while i was checking the newly repaired board by plugging in the climate control unit bare without the housing, i believe i may have shorted it on the headunit surround. Climate control unit still works but now the keyless entry doesnt work along with the dome light not turning on when you open the door. to add to this tricky situation, when you start the car and remove the key ( i have a turbo timer so car remains on) the keyless entry works. the dome light also works when you switch to the on position. fuses were checked and all ok ive deduced that the short somehow has messed with the smart entry control module as that is what controls the keyless entry and dome light on door opening   you guys wouldnt happen to have any experience with that topic lmao... im only laughing as its all i can do right now my self diagnosed adhd always gets me in a situation as i have no patience and want to get everything done in shortest amount of time as possible often ignoring crucial steps such as disconnecting battery when stuffing around with electronics or even placing a simple rag over the metallic headunit surround when placing a live pcb board on top of it   FML
    • Bit of a pity we don't have good images of the back/front of the PCB ~ that said, I found a YT vid of a teardown to replace dicky clock switches, and got enough of a glimpse to realize this PCB is the front-end to a connected to what I'll call PCBA, and as such this is all digital on this PCB..ergo, battery voltage probably doesn't make an appearance here ; that is, I'd expect them to do something on PCBA wrt power conditioning for the adjustment/display/switch PCB.... ....given what's transpired..ie; some permutation of 12vdc on a 5vdc with or without correct polarity...would explain why the zener said "no" and exploded. The transistor Q5 (M33) is likely to be a digital switching transistor...that is, package has builtin bias resistors to ensure it saturates as soon as base threshold voltage is reached (minimal rise/fall time)....and wrt the question 'what else could've fried?' ....well, I know there's an MCU on this board (display, I/O at a guess), and you hope they isolated it from this scenario...I got my crayons out, it looks a bit like this...   ...not a lot to see, or rather, everything you'd like to see disappears down a via to the other side...base drive for the transistor comes from somewhere else, what this transistor is switching is somewhere else...but the zener circuit is exclusive to all this ~ it's providing a set voltage (current limited by the 1K3 resistor R19)...and disappears somewhere else down the via I marked V out ; if the errant voltage 'jumped' the diode in the millisecond before it exploded, whatever that V out via feeds may have seen a spike... ....I'll just imagine that Q5 was switched off at the time, thus no damage should've been done....but whatever that zener feeds has to be checked... HTH
