oh okay, Well its pinging at the start when i take off whilst still cold, on boost etc and when warms up and giving it too it runs sweet just at the first stage ie, engine temp 20 odd deg and air temp 8 deg in the cold mornings,
so you think its air temp comp could someone pls verify
how about engine temp comp?
i dunno
I think you need to adjust the air temperature compensation table (via laptop).
Frankly, I don't worry about it running lean "off-boost" - only when I get it into the upper load bands.
doesnt the engine temp correction take care of that, so it wont ping when cold ?
Yeah it will if its setup properly, can be hard for the tuner if you dont leave the car with them so they can tune it at those temps so thats where a bit of guess work might come into it. I idle my car till i see 55-60 degrees water temp before i drive it and dont boot it till its at operating temp, but each to their own i guess.
thanks for the help those who offered.
its all sorted ,finally got a laptop, and just richened up then engine temp compensation a little bit up to the 40deg mark runs a little but rich now but better than lean, i suppose i just moniter it over the next few days but last two since have been a-ok, driving away at 12degrees engine temp
and where do i get this software? but i am pretty happy with my overall tune. lucky had a good tuner, but there is always everyday improvments to be made wouldnt mind saving some petrol
New software about to be released that will make these easy ECUs to setup and the base MAP list is quite good now.
i dunno
Is the wolf controling the idle speed via IAC valve? Chances are its pinging cold as there will be about 4 -8 degress more timing on top of the main table at around 30 deg ECT.
nah i got it sorted with the slight changes i made, i am 99.% sure hasnt done it since anyways
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
