Hi there....anyone knows who can re-thread the thread on the gear stick? The thread on my gearstick has worn out and i cant screw in my gear knob at all.
PICS UP further down in the post....Anyone who can fix the problem?
Edited by J-Boy
Cheers~
Try some plumbers thread tape and something sort of removable strength thread locker.. might work i guess.
How the hell do you wear down the gear thread?? :P Do you have a habit of unscrewing it at the lights or something??
Hmmm...where can i find an engineering shop? And wot's a plumber's thread tape or something? Sorry im not too familiar with those stuff...well the thread on the gearstick was already worn out when i bought the car, i also dont know how the garage in japan managed to do that.
Anyway that's a genuine Trust Gracer front bar, it came with the car.
plumber thread tape..you wrap it around the tip of the gear stick then put the gear knob on..basically tightens it up and secures it right...but once your screw the knob on..dont turn it back or else you'll have to pull the tape off and do it again.
I'm jealous :), looking for a decent front bar to replace my busted up one and noone can tell me what type it is so i cant get the same style
Where can i get this plumber thread tape from?
Hmmm...try looking on yahoo auctions fer 32 GTR front bars, definitely can find something in japan, the GTR32 kits here are pretty limited...im trying to find trust side skirts n rear pods to complete my kit too...got a top secret GT wing with CF plates and CF canards but i dont fit them on fer use on the street.
Well i have tried using the plumber thread tape and it does secure the gearknob a bit better, at least it does not slip out easily unless i used force and pull it out...but the knob cant be screwed tight still, as in it still turns n turns...but well it will do fer now i guess. :P
If you reckon the gear knob keeps turning even when it bottoms out, generally means that either the thread on the stick is stuffed or the thread on the knob is stuffed. A few edges could be chipped off, or even most of them.
Just out of curiosity, does the gear knob even have a thread in it?
If so, is it loose to turn onto the gear stick? It could be the wrong thread or wrong size, and someone previously has just jammed it on and cross threaded it which has made it how it is.
i got mine off of ebay cost me like 89 bucks and it is sexy. nismo one comes in a mad little nismo box and i checked with the nismo catalogue at work and it was the same. got a price through work and they wanted like 115 bucks for it so im happy
Well i know its not the thread on the gearknob itself because i had it trial fitted onto another gtr and it fitted perfectly, so it is my gear stick thread itself. The thread tape isn't holding it anymore....i really need to rethread the gear stick....anyone can tell me who n where does re-threading?
Cheers~
well having your shifter re threaded isnt going to help you much, as the new thread will be thinner than the diameter required to fit your shift knob.
i suggest you go to a spair parts or wrecker and ask for a shifter, or buy yourself an aftermarket shifter.
you wont have much luck at all putting your gear knob onto the shifter once you re tap the thread.
If I could see it I could tell you whats wrong and maybe fix it.
Does the thread on the the stick look OK? or is it worn down and lumpy insted of the usual /\/\/\/\/\/\ shape? You can get helicoils that repair threads or I can weld it and rethread it, without seeing it, its hard to say what to do, post up a pic to give me a better idea.
Hey there...well i can still see a bit of the ^v^v^v pattern..but certain parts feel a little smooth, so that might be the reason, im very sure its the thread on the stick that is the problem and not the knob...hmmm how can i meet up with u to let u have a look...? I will try to take a close up picture of it tmr and put it up. Where is helicoils anyway? It sucks cuz i cant change gear as smoothly especially when changing faster, and it doesn't help with an aftermarket gearbox that is really stiff n hard.
Cheers~
if u are looking for an engineering shop, if terry cant help ya, then just look one up in the yellowpages. there should be heaps in brisbane area. just go to your local industrial area and your will surely find a metal shop. they can do anything thats why they are metal fabricators. :laugh:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
