...my 2c. TD06 will go punch for punch with turbos in its power range.
But at the power figures you are looking at you will need a TD06-25G, again i think they are a better turbo then many of the Garrets getting around based on the results i have seen on a particular R33.
rods, make no difference
pistons, make no difference
cams.. some difference
Obviosuly you using slicks to run the 11 flat.
So GT30, 550hp version will do that for you on a bit of fuel.
I wouldnt used the trust, power delivery isnt the greatest
Well the thing that keeps me coming back to the Trust range of turbos is how my so called laggy turbo compares to some of the other Garret setups that are making the same power. With the exception of an R31GTS-R nothing is clearly better.
And i keep coming back to this plot of a std RB25 with HKS3040 setup with baby cams and Greddy plenum, compared to another RB25 with Greddy plenum and baby cams only it had TD06-25G setup
roy that dyno chart is with the td06-25g yes? it gets 327rwkw at 7500rpm, obviously has cams, but thats done on pump fuel? also comes onto fullboost a little late, 7,500rpm.. at what psi was it on?
Edited by LTHLRB
My understanding is that it is on pump fuel.
the while story is that the 3040 did have a big A/R exhaust housing, and i dont think the tune was quite as sharp as that of teh 25G setup.
And NIB, sure post away but they wont mean anything as different dynos in different states. (and no offence but Perth was punching out some bizzare numbers there for a while with GT30s)
These two particular cars were at least on the same dyno, with the 3040 owner pretty sure that the 25G setup is the way to go. Both engones saw plenty of love at race/drag tracks/strips so they werent hand grenades either
Perhaps the interested parties (they know who they are) could confirm all the details that have left me a Turst groupie :bunny:
The 3040 comes on boost way later then the 25G, mostly due to the larger A/R housing. The 25G is making 176rwks at 4,500rpm and has just hit its stride @19psi.
...and yes im talkign out my ass based on the opinions of friends...and they are only dyno sheets. But based on the reliable info i knw of the 25G takes a lot of beating
oh ok fair enough, because on what i have researched, the 30/40 600hp BB turbo with a .82 exhaust housing could have fast spool and get 300rwkw safely and easily and the turbo is save to go anywhere between 20 and 38psi.
I know the bigger cams u get, the more power u make with less boost. So u get a pretty good step cam and a decent grind for your application. Everything ranging from fuel to the tune to the boost your running aswell as the turbo hasto mix perfectly, for the best result.
Can compare both Turbos on the same dyno.TDO6 have trouble with their thrust washers also.About 6 weeks ago we did a GTS club car swap from TDO6 to GT30 as the TD06 was way to laggy.Was chalk and cheese being a much more competetive car now.We had the same power with both but vasty wider power band with the Garrett.
That would be interesting to see.
TD06-what vs what model GT30
Interesting topic...
I did this same homework about 4-5 months ago...
I found after speaking to many people that the Trust TD06-25 was the best option for an Rb25 engine... 2 reasons. The autobarn sponcered R33 in sydney was and has been doing mid to high 10's for about 1 year now on pump fuel and still internally stock.
Secondlly you can get a whole kit from trust... I mean all the bits needed to make it all work for an r33 skyline. Including all washers/gaskets/pipes the lot... Only trust and HKS make such kits that include everyhting...
I hate hidden costs...
I spoke to Matt Spry about the right turbo choice also... His recomendation was to go for the Trust unit over the garrett as there are so many garrett turbos and design types who really knows what their getting... He mostlly aggreed with the kit idea for a DIY install...
He said HKS would be nice also but a little pricey... Then i enquired about the 11 second Trust kit with autobarn to find out it is $7900... So i gave up and decided to buy another house...
Where is this autobarn 10 second R33? Haven't seen or heard much about it, would be interesting to add another GTS-t to the drag ranks.
The 25G compressor is more like a GT35R sized comp wheel than a GT30R one, when something works why try to change it?
Call autobarn doughboy...
Thats where i heard about it...
One of their guys owns the car at head office in sydney. He is one of their purchasing officers or something. It has autobarn decals all over it.
I was told by autobarn virginia about the car after enquiring about getting a kit for mine.
I run a td06-25g on a 25det... make similar power (little more) than that shown in the above dyno graphs and swear by these turbos.
Also ran one (smaller trim) on my old SR20 - 180sx and have never had a problem.
As for ppl saying they are old hat and non responsive, I beg to differ, I make enough boost to REALLY throw you back in the seat by 3,800rpm which only increases through the rev range.
Have lined up a few cars with similar trim/specs + comparable garrett turbo's and left them wanting on more than one occasion and thats with a cracked turbo manifold and a less than flattering tune :P
Its easy to jump on the "new technology must be better" bandwagon... but as they say, if it aint broke, then why fix it and I reckon Trust are onto a winning recipe with these turbo's personally.
/2cents
Poor example graph IMO.
there is no way the HKS 3040 is that laggy. Simply no chance its only making 240rwkw @ 5800rpm.
There is something very much wrong with that comparison
considering my GT30 (garrett version) delivered power much smoother than that 25g graph.
Its not about making the numbers, its power delivery.
The older Trust turbos power delivery is snappy and that causes wheelspin. Yeah it makes the car feel fast as it comes on boost with a rush, but the GT30 i had was so progressive you didnt even know it was feeding in from 5 psi to 20psi
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
