  • Replies 52
i got my mate who does installs for a living to put my 7x10's in the sides in the rear...you know where you put your arms. and put 6x5's in the rear parcel, looks and sounds good. All for the reason of not wanting a sub in the boot.
wouldnt a sub n amp be cheaper? or didnt u want to loose ur boot? a decent pair of 6x9s would have had enough base if u didnt want subs.
subs and amp take up so much room in the penuy line boot.
after reading this i decided to chuck 6x9"s in the rear also they work a treat, only did it as my splits were rattling in the back (really annoying) so went the whole hog with mdf im more than happy with the results, did it also so it sounds good when i take the sub out which is quite often cheers for the write up
I have all speakers hooked up to the amp but yeah didint want to take up space in the boot, hence the reason for all the trouble and money. ;)
Hi Again Eug, Thanks for the reply,I have decided to do the job the way you did but would like to keep the speakers straight in the back not rotated ,to fit better as you did, is this possible??
I really like the look of the stock speaker grills in the back can they be used over the new speakers??
Can you tell me how to remove the seats properly and how to take the stock grills off without breaking them, also did you screw the mdf shelf into the steel parcel shelf or just let the seats and the snug fit hold it in??
How thick was the carpet you used to cover it or what type was it??Cheers Rob.
I remember a member here "fhrx" telling me its possible to fit 6x9's nicely using a method with specially made spacers. This would make the install look very professional and without the need to make a new parcel shelf or hack the current one.
  • 4 weeks later...
this might be too late but....
the speakers have to be angled due to the shape of the steel parcel shelf holes (have a look from underneath) dont think you can really use the old grills without butchering your old shelf plus not worth the effort IMO
no need to screw the shelf down if you make it the right shape it fits in very nicely and gets held in by the seats and the plastic side panels
can get thin/backless carpet from jaycar and probably a shitload of other places
I put 6x9s in my parcel shelf using the stock piece and just cutting some 10mm MDF rings one under side glue on with liquid nails and another on top to get the speaker to clear everything but with the sides cut on a 45 degree angle so it slopes down to the shelf then moulded carpet over it.
__/------\__
kinda like that with the speaker sitting on top, .... and I didn't need to make a whole new mdf shelf...
the sound difference in going to an MDF shelf is amazing and well worth the effort IMO, only takes a few hours looks better and I get shit loads more mid-low bass now with zero rattle
exactly! it pretty much acts as a deadener or a sub box.
  • 2 months later...
i know this was done ages ago but im going to do it in the next couple of weeks so hear is my question, nice and easy, could you use the original flimsy parcel shelf as a template for this? or is a different one in order due to the difference in size between the mdf and the stock one?
Yes you just use the old flimsy parcel shelf for a template. this way all the platice vents and the lines in the sides for the interior plastic to fit all line up.
and it looks nice and factory :D just without the grills
I can't really imagine any otherway to create a template for your parcel shelf without using the old one though :huh:
Edited by sIIgtst
i put 6x9 in the back of my r33 i used the factory shelf and brought 2 spacer rings that the carpet on them was exactly the same as factory looks really great sound good have a small amp in the boot + plus my window tint is so dark you cant even see inside the car lol
nice to see this thread being used :(
yes you do use the original one as a template. however, modification to the stencil will be required depending on how thick your mdf will be. as you can see from one of my photos the edge that meets the rear windshield will need some sanding/sloping. the thicker the mdf the more you'll need to sand back.
  • 3 weeks later...
    • For these last 7 years of ownership, I've always had to use a small scissor jack under one of the front tow hooks to raise the front just enough so my low-profile jack fits under to reach my subframe jack point. I'm beginning to get annoyed of always having to do this. Are there any lower low-profile jacks that fit under the gtr lip on a dropped car?
    • Seat of the pants assessment of the new intake: The car is way less "doughy" when hitting the loud pedal, especially off idle when stopped or in traffic, I did use a cheapo lazer thermal thingo to measure the temp around where the pod filter got its air, it was between 55 - 60°C, in saying this the car was shut off and not moving, so the OEM intake pipe was not supplying any fresh air to where the pod was when the car was at least moving A weird bonus was induction noise on the throttle in the cabin increased a bit,  I was worried that I was actually going to lose some of that induction noise I love so much, outside though, when I got the daughter to do a WOT drive by pass for me, the induction noise has increased alot when on the throttle, not quite ITB doort, but well up there I'm extremely happy with the results and have been exploring the country roads in the region  As for house mods: 1.New front fence is up and is awesome, it really upgraded how the joint looks from the street, and the added security is nice 2. Electricians have replace some interior lights, and with more lighting in the garage, a few new motion detecting lights out the front above the garage, front room, and at the front door, which I have already found heaps helpful coming and going, also now has fancy pants CCTV all round the house The only hold point for power though is the solar and batteries due to supply issues, although this will happen over the next few weeks 3. I have done a heap of landscaping out the front and I'm almost ready to do a new small retaining wall with some nice blocks to replace the brick and cemented in rocks around the raised garden beds cemented in river stone "was the fashion at the time" the house was built. I currently have a pallet of retaining wall blocks and 2 bulka bags of 20mm blue metal to replace the wood chip that is in the raised garden beds around the house 4. I now have 3 big raised garden beds for out the back to grow some vegetables, about 70cm high, 200cm long and 100cm wide 5. My 2 compost bins are already pretty full with brown, green and kitchen waste from the landscaping I'vedone so far, but they will probably take a few months to break down, so anything else that gets chopped, trimmed, and kitchen waste will just start filling the base of the raised garden beds to about 30cm before I start throwing 40cm of good compost, and stuff, for the vegetables to grow in, I'll need a few ton of compost and soil, but the local supplier can sent me bulka bags of the stuff Basically the logs, wood chips and a few strategically placed rocks for drainage, will give the beds some good organic materials down low to break down over time, and they will hold moisture during the warmer months to save the water in my big arse water tank if we don't get alot of rain So, all in all, the car and house mods are going well, and I'm really enjoying being retired, I sleep in too 0700 and slowly plod around inside until I feel like actually doing anything, and only work in the yard for as long as want, which has actually been alot over the last few weeks,  although when you look at it, it seems that not a huge amount of work has been done,  until I look at the before I started the work pics Happy days and good times indeed
    • hahaha yeah. Plan is to get side skirts and probably just rear pods. But going to do them one-by-one. I've got a set that I really like from RHDJapen, but that one isn't shipped to AU. So need to find someone who can get it for me
    • Here's an idea, answer the questions I asked you as they are trying to work out WHY the LSD will be binding up in a straight line.
