G'day Fella's.
I’m installing some new HKS cams and want to replace the valve springs, so I was wondering if anyone could tell me what the installed height of the valve spring (in&ex) on an RB25 is? I can only find the specs for the RB26 in my R33 service manual and I thought that they'd be different seeing they are solid lifters and all.
Does anyone have any recommendations on what springs to use and where to get em from?
Also I don’t want to pull the head off to do this job, has anyone bought or made a good tool for this job before? as the only tools I have to do it won’t fit or need the head off to do it.
Any thoughts would be appreciated.
https://www.sau.com.au/forums/topic/113984-valve-springs-for-rb25det/
G'day Fella's.
stock lift is 8.5mm, and if you wana do a changeover without taking off the head, get a hose fitting the same thread as your spark plug, use your compressor and compress the cylinder.( watch fingers, engine will turn over) and then remove springs... the compressed air stops the valves falling into the bore.
Edited by danielson
Cheers man, the problem im having though is compressing the spring so im able to crack the collets off. As the spring compressor I have needs to go down the side of the spring which there is no possible way with the RB heads, I need some sort of tool to press the spring down I may have to make or modify a different tool to do it, so I just thought someone else may have done the same thing and be able to point me in the right direction of the easiest way to do it :D
:laugh:
I'm pretty sure that they would still be fine, I'm using them on 8.9mm of lift :D
Hmm maybe but it would always worry me, so im gonna look about a bit more before I go back to them
Edited by muaythailuke
Performance Springs do them and for the NEO as well now.
Hmm yeah well, they are the springs I have in the car atm and they are shit sorry to say, I dont mean to bag this company out but I pulled an in & ex spring out and both only just had 50psi seat pressure and neither got anywhere near 200psi even at full compression :P and id bet if we had heated em up it would have dropped even further so they are just way too soft so... i think i will steer clear of them thanks.
dumb question but will the tomei 8.8mm valve springs be ok with 8.5mm stock lift with my tomei step 1 cams??
Yeah they'll shit it in, they are recommended for anything up the 8.8mm lift so 8.5mm will be fine :(
Im thinking of getting myself a set now as I cant find anything else, my intake cam has 8.8mm lift so it will be fine but my exhuast has 9.0mm but I cant see that 0.2mm will make that much difference but im trying to get some spec's on them to find max coil bind hieghts and seat pressures etc.
muaythailuke, would the queensland performance spring be better in my application where im only using 8.5mm lift? what seat pressure would stock valve springs use? what were you reving your motor too with those springs? did they cause the valves to float? at what psi ? rpm?
Ive spoken to a few people that have used the qland performance springs and had no worries but other have ive spoken to wouldnt use em in a fit, I may have just got a bad batch I dont know but.... :
The problem I was having started about 4000rpm and just got worse, even at low boost (8-9psi)I had problems and just got worse with more boost (up to only 15psi).
Even when I chaged back to my standard cams the problem was still there.
My rev limiter is set at 7700rpm and I couldnt rev it anywhere near that with these springs.
The seat pressure of the standard spring I dont know but I going to test them once I find my old ones but the description that my tuner gave me after he had tested the performance springs I pulled out was, "just a couple of wound up paper clips"
Hope that helps
:P
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
