***UPDATE***
Want it sold or traded sooner rather than later. Come forth and smother me with offers :pwned:
As far as specs go it's done 107XXXks and the head is freshly recoed with new belts, valves, valve guides and an acid dip to clean the ports. As the car is a late 1993 model, it has the R33 style crank and clutch/gearbox setup with "fully sick" lowered springs that came with the car - the only mod that came with the car actually...
Stock turbos/dumps running 14psi with custom front pipes joining at the "cat" ( I use the term cat loosely) onto a 3inch straight through system finishing with a cannon.
The gearbox has been rebuilt with 33gtr internals and the clutch is very noisy as it is a Nismo G-Max III triple-plate. A little bit of an overkill I admit but sounding like a super-tourer is kinda cool and 1.6~1.7s 60 foot times on nangkangs kick-ass. The Nismo gear-knob adds 50ricekws.
It has a HKS filter in the standard airbox, although the airbox has the lower face cut out for more flow and the AFM's have been de-meshed.
The fuel system is stock other than the Walbro pump and an old school SAFC tweaking the mixtures. I have the stock ecu and a Central 20 chipped ECU from Japan. Both will go with the car.
The show-off valves are twin Apexi Dual-Drives and are adjustable from loud-ish to rice boy.
The most obvious change outside the car is the bonnet which is $1800 worth of 100% carbon fibre. There is no fibre-glass underneath, it's carbon the whole way. You could probably hold a rave on it with little chance of it buckling.
The brake and clutch cylinders have been rebuilt and the pedal box cut, rebraced, and re-welded to the car to stop the clutch tearing the pedal assembly off the firewall.
Front and rear strut braces for some stiffness (and something to look at in the boot I suppose) are also fitted.
The car managed a 12.4 Jambo 2004.
It has factory floor mats, I don't know why that's exciting but everyone mentions that I have them... Go figure.
It has a Gizzmo dual stage shift light fitted.
The rims are 17x9 Trial Try-Force Zeldas which you either love or loathe, personally I'm a tri-spoke bandit and love them obviously.
The negatives - the A/C has two settings, hot and hot - needs a regas. The passenger side headlight is also seated 1cm back on one side after my fiancee delicately displaced a motorcyclist from his bike in May - see photo below.
With the car as is I was looking at the low 20's or trades with cash my way.
Edited by Squizz
https://www.sau.com.au/forums/topic/114398-saleswap-32-gtr-cheap/
  • Replies 54
Posted Images
id swap :( but my car aint auto :)
im serious i love that car!!!!
if ur interested in a manual r33 1996 s2 with nice mods let me know :(
Edited by mass_iv
i loved ur wheels squizz everytime i saw it at uni i was like " if i ever get a skyline i want tri-spoke wheels..." let me know when u want to come around have a look at it squizzis
Damn...Oh my, hope I am not too late...
How bout a swap for my classic aussie muscle car (auto of course)?
Specs? Of course...
1972 HQ Holden Premier Sedan,
Mild injected Holden V8,
Auto Transmission,
Strong Diff,
Very safety oriented,
Only driven on weekends.
Whadaya recon??
Want to meet up for inspection etc?
:D
I have a 2005 VY II Commodore, white in colour. 40000k's. Wife hates it because A. it is an auto B. it is a great white whale. Nice comfy car Squizz??????
I would have to shoot myself. What are they worth?
"I have a 2005 VY II Commodore, white in colour. 40000k's. Wife hates it because A. it is an auto B. it is a great white whale. Nice comfy car Squizz??????"
"I would have to shoot myself. What are they worth?"
they are worth not much more than a packet of matches to set them alight hehehe.
seriously if you swapped for an aussie made car youll regret it for the rest of you life (no offence)
squizz give me a call and we can meet up re your PM
    • Yes I can see how that would put you off HFM, especially with the price of good quality brake fluid. From what I understand it as you say the BM50 is the standard BMC for a R32 GTR, I must admit I would like to go far a Genuine Nissan BM57, but lack of cash prevents that at present. With the price being so close between the genuine BM50 and BM57 a BM57 New it seems a better choice as you gain that 1/16 bore size with the BM57, I would be interested in how much difference you feel with the BM57 fitted. I am going to take SteveL's advice in the short term and see how much actually comes out of that proportioning valve vent and save up for the Genuine Nissan part. Thanks for clarifying the HFM failure
    • Thanks mate. I just got the post inspection 1/2 done from state roads when the starter motor packed up, either that or the car alarm system is having trouble.  OEM part number 23300-AA112.
    • Hi, I though I was coming to an end in finding a replacement starter motor for a rb25de neo. I came across a starter motor from Taarks and a message below stating: Direct fit. 11 Tooth count. All below part numbers have been superseded to 11 teeth. Can some body shed some light on going from 8 teeth to 11 teeth apart from 36-month / 25,000 km warranty for passenger vehicles to 12 Month Warranty. Compatible with the following Nissan part numbers: 23300-20P00 23300-20P01 23300-20P05 23300-20P10 23300-20P11 23300-AA111 23300-AA112 23300-AA300 23300-08U10 23300-08U11 23300-08U15
    • Low battery? Maybe check capacity? I know first-hand, on BMWs if your battery drops below 80% capacity, it starts causing strange issues.
    • 8.5 +37 = should fit rear, but I think it'll hit on front. What you want is low 30s/high 20's front, mid 30's rear. That 17" screenshot you posted looks good, I'd run it on my R32 (but that's long dead now). For tyre sizes, my rule of thumb is: 8': 235, 9": 255. But that's just my opinion. Nismo sizes: 18x8.5+35/18x9.5+38 is a good starting point.
