  • Replies 151
Posted Images
Wang looks like being sold.
We are asking $3000 for the engine package which includes the turbo, coil packs, loom and ecu but we will listen to genuine offers.
Seats can be sold as a package both fronts plus rear for $700 the set.
Diff with drive shafts and hubs $600
Ok, still have a tonne of miscellaneous parts available... particularly from the interior! All these parts are up for sale as well, if anyone needs anything just shoot me a PM with a reasonable offer.
I want to get this gear moving ASAP!
Wogboy; got the brackets.... no surround and no knob :laugh:
bcc23; that would be the gear shift surround... we do have it but I don't think it's for sale (are you after the manual one or auto?)
Stan it doesn't have the little tray that sits under the rear ashtray does it..some cars have these others get the shite blank-plate!
While I'm at it, do you have a spare blank-plate next to the headlight height adjuster?????
Thanks
No tray under the rear ash tray... we got the shite plastic one and that's been sold already.
I will have a look to see if we have that "cap" you are talking about - not 100% sure if we do to be honest.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
