Hey,
Have 2x Z32 AFM's & also have 4x Q45 AFM's.
All in perfect condition and come with plugs.
Z32 AFM with plug = $250 + postage
Q45 AFM with plug = $330 + postage
Send me a PM for details and pictures.
located in Adelaide can do COD if you would like or pick up.
https://www.sau.com.au/forums/topic/114824-z32-afm-q45-afm/
mate, you need to retune once you fit... you would benifit from it though only if you have aftermarket ECU or a remap (like me :worship: )
Are these new or used? Condition? PM me please...
https://www.sau.com.au/forums/topic/114824-z32-afm-q45-afm/#findComment-2119016
hi mate whats the difference between the z32 and the Q45 afm, I have a turbo r33 with cooler, exhaust, bigger turbo, fower fc etc. dont know much about afm's
Luke
Im guess from your mods that would would be pushing somewhere from 180rwkw upwards.
Thats a guess as i dont know what turbo your running.
The standard AFM runs out of puff about the 180rwkw-200rwkw and as you have a power fc it should have a premade setting on it so just tell it you now have a z32 afm and it will adjust the readings. This should allow you to drive the car around from day to day, but a tune could still help perfect the A/F mix.
The main difference is that the Q45 AFM can read more power than the Z32 but depending on what power your aiming for you may only need the z32AFM. Both are the same size but the Q45 reads and can produce more power.
https://www.sau.com.au/forums/topic/114824-z32-afm-q45-afm/#findComment-2119129
  • 4 weeks later...
Hey,
any more z32 afm available? if so how much for one posted to 2110 nsw?
cheers
https://www.sau.com.au/forums/topic/114824-z32-afm-q45-afm/#findComment-2197459
Have a mate (Dan - Marjinal) who is actually on this forum who needs a Z32 one ASAP (he is currently off to Adelaide to drift) with mine off my Zed so we need another asap. PM your contact details etc and I will grab one of these (provided you have one left) from you on Monday (I am unfortunately off with the bloody Army for the W/E).
MattB
https://www.sau.com.au/forums/topic/114824-z32-afm-q45-afm/#findComment-2202581
GDay, Im posting for a friend (who is a member, but without internet at the moment). He needs a Q45 asap. Are these new or used? If new or in excellent used condition, he'll grab one off you with postage to Brisbane.
Thanks,
Shaun
0414972596
https://www.sau.com.au/forums/topic/114824-z32-afm-q45-afm/#findComment-2202972
Thanks,
Shaun
0414972596
I got in contact with him ,all sorted,
cheers
https://www.sau.com.au/forums/topic/114824-z32-afm-q45-afm/#findComment-2204924
3. Please pay atention to pic 3 as you can see the person has broken off the plastic clip around the pins, the pins are still in perfect condition and a plug still fits straight on with no problems, but can slide off if pulled on hard.
https://www.sau.com.au/forums/topic/114824-z32-afm-q45-afm/#findComment-2205628
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
