I have some adjustable whiteline swaybars for my R32 and i'm just looking for some recommended settings for my car, hard/medium/soft?
the car is a weekender that spends most of its time in the hills and will sometimes see the track for drift and grip racing!
I was thinking medium/hard for the rear and medium/soft for the front!
Can people with experiences in this field please give me their input!
cheers in advance!
https://www.sau.com.au/forums/topic/115002-whiteline-swaybar-settings/
hey iam fitting mine up next week ill let you no how they feel, ill be setting the rear hard and front medium....just dont set the front to hard or youll be understering!
i'd heard not to set it too hard at the front, for that reason i was going to go soft. let me know how you go!
Ditto this is so much a personal preference thing, and a sum of the other mods you have.
As for setting the front to hard causing understeer, ill enter my car into evidence as exhibit A for not understeering...and R32_bigboy as exhibit 2 as he now has my swaybars and we set them to hard both front and rear and it handles nicely....so?!?!?!
mmmmm
i'm thinking i may set both to medium to start with and go from there!
mmmmm
I have both my sway bars set at medium.
I first installed these as the only mod to the standard suspension, and noticed a massive improvement - with very little under steer.
I have since installed everything else in Sydneykids package of goodies, and made another step forward in the cars handling. However, now at the limit, it tends to under steer a little. As such I am now considering stiffening up the front sway bar to hard, to dial this out. Thoughts?
Edited by Ryno
I have since installed everything else in Sydneykids package of goodies, and made another set forward in the cars handling. However, now at the limit, it tends to under steer a little. As such I am now considering stiffening up the front sway bar to hard, to dial this out. Thoughts?
First thought is that you have it upside down, Miss Jane.
If you want less understeer soften the front bar (or stiffen the rear). Increasing roll stiffness with anti roll bars will (all other things being equal) degrade the grip at whichever end of the car you make the adjustment. Which is why you start tuning with the bars on soft and then stiffen things up at one end to balance the car out.
Personally I adjust the opposite end to that with a problem. For example, to lessen the understeer I stiffen up the rear anti roll bar. If the rear bar is at full hard and I still have understeer, then I soften the front.
:D cheers :nyaanyaa:
:( cheers :D
Sweet, stiffening the rear it is.
There are a couple of things to note:
1: In steady state cornering anti roll bars kill grip! An ugly truth, but there it is. They work by transferring load from the unloaded side of the car to the loaded side. Note that after a point the friction coefficient for a tyre falls away the more heavily loaded it is. (This is ignores temperature effects)
2: It may well be worth comparing the cars grip levels with the front soft/rear at medium with the front on medium/rear on hard. Remember balance and grip are two different things. Try it see if you can find which you prefer. (This all assumes one level of adjustment is sufficient)
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
    • Thank you so much for the help
