Date:14 June 2006
Arrival: 730am registration
Break: 12:30pm
Finish: 4:30pm depart
DNA RACING WORKS invites ozhonda.com , pulsar.org.au, skylineaustralia, clubrsx to attend a track day. the day is just to get out and socialise and have a good time
Note: Each participant will be required to produce their drivers licence for legal purposes and sign a course indemnity.
Places Availible: 37
Cost $165
Spectators Free
With the positive response of the last track day i figured its time to have one at a different track.
The day will be organised by Ian Luff and all drivers will have a ride along with a pro to get one on one tuition.
Monies need to be recieved by 14 May 2006
contact jimmeh on 0405 072 590 or [email protected] or PM me
Programme Format:
The group will be broken into three teams - each with their own ILMVA personal trainer who will coach
and motivate them to move outside of their comfort zone and achieve success, both individually and as
part of a team.
Over the course of the day, there will be three (3) workstations that each group will contest (each runs
for approx 45minutes with a 10 minute changeover). At the conclusion of all three activities, the track
will be opened up for a ‘speedfix’.
The track will close at 4:00pm and guests will assemble in the VB Room for a Trophy Presentation, for
the following awards, Top Gun, Hard Charger, Hot Shot and Skilled Driver.
Drive Activities
Super Slalom - A driving discipline where eye-hand co-ordination and throttle balance is needed. Marked
with soft plastic traffic cones, the objective is to negotiate the course in the best possible time without
hitting the cones.
Cloverleaf - This high adrenalin driving test will really sharpen a driver’s reflexes. Rapid steering input is
needed to make it to the finish line with smoothness being the key to success. A great sense of direction
is needed to gain maximum points.
Hill Climb - The name says it all, but we provide an extra challenge. Again, the course is marked with
plastic cones with one part of the course wet down to create a driver skid control test. Lots of fun
guaranteed and plenty of sideways action.
Open Track - After lunch is when u get to put you newly learn skills into practice.
keep it tuned
Edited by mrjdm
https://www.sau.com.au/forums/topic/115762-track-day-at-oran-park-14-june-2006/
I think you may have missed what i was trying to say, i mean, enter one car with two drivers and split the events between the two drivers. As i would only enter for the last part, so the rest of the day would be a waste
illl drive your gtr in the morning session :D:thumbsup:
the whole day will take place a oran park
sorry i think you misunderstand. there are 3 comonly used circuits at Oran Park. Oran Park south, Oran Park Nth (go cart track) and Oran Park Gran Prix.
edit: primordial beat me to it.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
