  • Replies 264
Posted Images
So Dan,
this SlidingPerformance Roller-bearing turbo spools slower than the stock ball-bearing turbo? You notice this difference?
doesn't any turbo with a larger rear AR ????
just a question dan
did you get the exact turbo off the shelf to what the site shows or did you get it customized some how?
why do you reach 10psi at 3,000 rev?
I thought you would be reaching it earlier because apparently Satanic reaches 11psi at about 1,800 revs. His turbo is customized though.
maybe you will need to tune your ecu?
My one isn't the 'off the shelf version' it has a larger exhaust side. Yes it is noticeable that it spools slower than the stock turbo, but when you look at how fragile and light the stock one is; it's no suprise. I'm pretty picky about lag and this turbo isn't bothering me in the slightest, especially when it kicks in :thumbsup: You can't expect stock response out of a turbo which will way surpass the current power output.
I could be reaching more pressure earlier by throwing some timing into the tune and removing some fuel around 2800-3000rpm, but I don't think there is a hope in hell of getting 11psi at 1800...I could only just get that with a stock turbo on my 10:1 compression engine!!!
I think most people out there, even with GCG highflows would be saying the same about where the boost kicks in.
I'm 1000% happy with it :dry:
hmm... Interesting Dan.
I hope mine will perform similar to yours.
Planning to install it next monday.
I'll let you guys know how it goes.
Hopefully its similar to yours Dan.
I also have the bigger exhaust size.
By the way, have you had any chance in dyno differences between the stock turbo towards this turbo?
No haven't had a chance to get it on the Dyno yet, also the turbo will take about 1000kms to run-in...until then you'll probably be boosting around 4000rpm like I was for 2 weeks, once everything had worn in and loosened-up it's awesome.
I have said this many times, so I apologise for repeating myself if you have read it before.
The GCG ball bearing high flow on the R34GTT made more power EVERYWHERE than when it was standard. That’s from idle to redline.
:dry: cheers :thumbsup:
I can't comment on power from idle, I'd assume more considering that the exhaust side is 1.5 times as big as the R34 exhaust housing...hence flowing more, hence more power.
I'd say there could be a slight difference in power with this turbo around the 2800rpm-3000rpm range as my tune had a lot more timing in this area and power peaked very steeply with the stock turbo (poor traction at low rpm)
Once again though I'd be interested to see a pressure log against rpm for the GCG if anyone has this info laying around? Then we'll have something concrete to compare with regard to spooling time (even though shaft speeds aren't available to us)
Currently the car feels a lot more street friendly.
I've actually found this interesting, as the GCG isn't as responsive as the stock turbo, so wouldn't be making pressure at the same rate, how would it have more power in the 2500-3000rpm range?
As mentioned before, I'd understand from idle to 2500rpm purely from the better flow of the exhaust, but this wouldn't account for any extra power in the rev range where the stock turbo is already at a decent shaft speed and the highflow just wouldn't be at the equivalent speed...there must be at least 500rpm where the GCG doesn't make more?
When I say “more power than standard” I mean SHOWROOM STOCK STANDARD. That’s;
Standard dump
Standard engine pipe
Standard cat
Standard exhaust
Standard ECU
Standard tuning
Standard air filter
Standard intercooler
I suspect what you are comparing is all of those things modified, but with the standard turbo. However that is obviously no longer STANDARD.
:( cheers :woot:
Edited by Sydneykid
Standard dump
Standard cat
Standard exhaust
Standard ECU
Standard tuning
Standard air filter
:( cheers :woot:
Ahh OK, you mean extra-shitty standard...yeah I'll go with that, the extra flow in just the housing would be an awesome improvement for a stocker which actually feels quite laggy in factory form.
but the GCG has a bigger compressor so even at lower spool it can create the same airflow.
That's true, but it still doesn't reach a shaft speed which would produce the equivalent pressure before the stock turbo.
Who would that be? SK? or PaulR33? I wouldn't be calling them keyboard mechanics....
The purpose of this post and forum is to promote open discussion and information, from all sides.
I havent heard anyone say that these turbos were shit, all I've heard is people's opinions, own trials and information they've provided, ultimately it is each persons own choice to choice their turbo for their own uses.
If anything I'd say most people have had positive feedback, and that's a good thing.
Ummm no...
I have had quite a few worthwhile discussions with both Gary and Paul, who are both knowledgeable.
I am referring to the sheep...so re-read my post and build a bridge...
Don't turn a good thread into your own self promotion... :(
Dan do you have this turbo in????
I am confused with all this GCG discussion...
????? its quite clear Dan now has this turbo installed, and seems to be happy with it
Yep the turbo is in, and I'm extremely happy with the performance (just to recap, feels faster running 10psi, than the stock turbo running just under the factory retard ~ 12psi)
Thanks Dan!!!
Can't wait to see what it pulss with a decent tune. So what is the pocket damage fo this little upgrade???
What are the specs seeing as this is not an "off th shelf" item???
tangles...thanks for the input...
    • Hi GTSBoy, Excuse my ignorance but what does a "Bad" Knee point mean ?
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
