I am guessing you can, but the extra length of the FWD transfer case and clutch pack would mean you would need the tailshaft as well which would be shorter than the GTS tailshaft. Duh.
I would think the bellhousing should bolt up Ok, not sure about shifter positioning, etc.
Sorry I cant be more helpful.
https://www.sau.com.au/forums/topic/116220-gts4-box/#findComment-2137543
I believe the floor pans are different ( to accommodate the transfer case) so probably won't fit. (pretty certain it's been covered before).
Hope you're not thinking of destroying a perfectly good AWD box so it will only work RWD.
https://www.sau.com.au/forums/topic/116220-gts4-box/#findComment-2138823
Yeah, the gts4 box takes up a lot of room. The transfer case is reasonably big, I think there is about 30 - 40kg of extra metal. Are you looking for extra strength or a 4wd conversion? If you are after strength the change to a rb25det box has been done several times, might seem more expensive tho but would be easier than cutting up your floor pan (you probably know this already). A 4wd conversion would need a new engine too for the 4wd sump (wont fit rwd engine) plus I dont know how much of the front running gear (if it will fit), could be a can of worms, buy a gts4 (they are brilliant :pwned: ).
https://www.sau.com.au/forums/topic/116220-gts4-box/#findComment-2139040
    • Congrats on the career change!  I did something similar at the start of the year too, left IT / corporate after nearly 2 decades. Soooo when's the motor coming out for the spark plug change?
    • Hi guys, long time no post as per usual! It's been a busy year so far, the biggest thing being a new job.  After 28 years in the automotive industry I decided it was time for a change.  I was losing faith in the industry and where it's heading.  Now in a completely different industry (electrical) working for a company that manufacture water pump contollers.  Not as sexy as cars but it's an interesting,  challenging industry. I now don't work Saturdays which is a bonus!  It's still 50-55 hours a week but having Saturdays ack after 28 years of working them is awesome!   No news on the GT-R but i did decide to add some more JDM goodness into my life....           1990 300 ZX.  She's not perfect but for a 35 year old car she ain't bad!  Just going to tidy it up a bit and enjoy it.  It's currently auto but will start stockpiling everything for a manual swap. It WILL distract me even further from the GT-R but im hoping not for too long! It somewhat proves a 6'8" freak can fit in a 300 ZX.  Sort of...  I drove it home from the previous owners house in Melbourne via Black Spur and Merton Gap (2 awesome bits of Victorian twisty road) and it was amazing!  Handles so well!!!   I don't think it would be worthy of a full build page but I'll post up some of the upgrades here if anyone is interested?  Cheers guys!
    • End game is to: - Remove all the slop from old worn parts - Adjust setup so that the wheels actually fit and the car is drivable (currently it is not because of the extreme rubbing on the guards).   Progress over the last couple of days, removed the rear hubs! Next steps: - Buy bushings - Replace bushings/bearings on hub - Reinstall
    • Cracked deck  And other cam snap stuff
