  • Replies 211
Posted Images
Dont have any photos. I think i have some photos of my first Renault back in the 70s. Not even a photo of my old Brabus.
Reading through peoples comments, it appears my car may only be as quick as my old Brabus, but it feels quicker.
Edited by Sputnik
Hi guys, here are the results.
Please note: TBA results are still being looked at. The competition was very close in the TBA items so its going to come down to 100'ths of a second i think.
I'd prefer to give it full time to calculate and get it right, rather than post a false result.
Im flat knacker @ work so it should only be a couple more days ;)
cheers
STi
Fastest - Shiraz Ali Patel
Consistent - Shiraz Ali Patel
WRX
Fastest - Chris Sleeman
Consistent - Chris Sleeman
RWD Sky
Fastest - Pete Blythe
Consistent - TBA
GTR
Fastest - Aaron Panozza
Consistent - TBA
Intruder
Fastest - Ray Evans
Consistent - Tharaka Pathirage
Highest MPH
Ray Evans @ 133
Most Improved ET
Ben Winstone (GTR)
Sh|tbox
Winner - Tarago
Runner-up - Lada
Im flat knacker @ work so it should only be a couple more days :)
cheers
STi
WRX
RWD Sky
Consistent - TBA
GTR
Consistent - TBA
Intruder
Fastest - Ray Evans
Highest MPH
Ray Evans @ 133
Most Improved ET
Ben Winstone (GTR)
Sh|tbox
Winner - Tarago
Runner-up - Lada
Have you got the times??
ye, ill post that up when i got time.
First and foremost was the results, the timings and stuff are secondary.
Trophies and the like are @ the July CLub meeting as i stated @ heathcote
Again, sorry for the delay, 7days/50+ weeks is not working too well at the moment :(
dunno why my MPH was so high
neither do i... but cant argue as ALL your times were like that.
However one WRX ran mid 120mph, but he told me that couldnt be right as the car had never gotten over 110mph or something close to it.
I'll be having a word to Heathcote about thier timing as im a bit intrigued as to how accurate it is, or rather it is not.
I've had isues before, thre is no way i ran a 12.1 with 111mph, would have to be closer to 120mph+
Ill see what they come back with :rofl:
That sounds about right dude. I ran my GTR on the weekend at Heathcote and ran a 12.8 @ 106mph.
My mates R32 GTR on one of his runs did a 13.3 @120mph (now thats a stuff up - that was the right side)
But Ash has a Rwd R31, would have to have a wicked fast 60ft time for that....
A 12.6-12.8 qtr will be done with a 106-109mph quite easily in a awd car with a 60 ft of around 1.7sec. This my experiance anyway with Evo's, Wrx's, Liberty's and GTR's.
It seems with GTR's once you get in to 11 sec teritory a good 60ft is hard to get, due to the fine line of wheel spin and bogging down.
That's my 2 cents worth anyway :D
My 60ft was a 1.86 (standard tyres - wheel spin). Your info is about spot on :D
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
