  • Replies 513
Posted Images
Satanic is a definite (hopefully all the goodies will be in by July 2) - time to test this thing out :thumbsup: *nudge* Adam *nudge*
NBP Team may have 2 other entries; another from SAU and 1 from RENEW.
immm in! as long as i get my suspension troubles straightend out! but july is verry far away so all good :thumbsup: now to get the cams thing done
ohhh btw i got stuffied coilovers... rekon i shud go and do the track day wid stock suspension instead?!... or would it be more beneficial to change em?
thanks!!!
Guys and Gal's,
Definately go to this one if you're one of those "I'm worried about my car getting wrecked" types. this has to be one of the best beginner tracks around!
Unfortunately wont be able to make it as I will be in Italy at the time..........but have fun!!!!!!!
holy shit its far......2 hours drive....so to get there at 8 in the morning I'd have to get up at 6:30.....ARRGGGHHHH
2 hours drive
get up at 6:30
earliest you would be there is 8:30 lol
unless you speed.. and I dont recommend speeding around there.. Ive been fined each time I have driven to wakefield.
Adam.. I cant afford a track day so do you still need a flagwhore?
Abo,
Are you coming? I look forward to seeing both of us improving our times, and I would love to do a head to head again.
If things work out the way I plan then to, I should have my Cam sprockets in and the 100 ron tune completed. I will probably boost up if I get this work completed.
Sam very keen to have you there. James - yes it's a big big day out but it's so fun you wont care.
Paul - Of course I'll be there. I'm still tossing up whether to do my secret mod before then or not so I may be able to keep up with you... we will have to wait and see.
Cefiro - CHECK
RB25DET - CHECK
SEMI SLICKS - CHECK
NEXT TO NILL TRACK EXPERIENCE - CHECK ;)
Should be interesting.....ahahaha
At least Wakefield is most prob the best track to get used to the car on!
Fun shall be had.....!!!
Question, what type of facilities will they have there for us? Will they be providing power? The boys will be trucking along a full tool kit and we're thinking about lugging along a generator if we don't have power >_<
Stan, you can hire a pit garage if you want, i think its $50 a day - not 100% sure though
Try calling wakefield during normal hours, they will be able to tell you about power in the free pits(carports).
The number is all over www.wakefieldpark.com.au
...so they will have air tools? Like to take rims off? That may be handy >_<
    • It is a kunfine Android screen . Does anyone know the wirering diagram of the fuga ??
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
