ok so its been said it can be done but you are confused to as how to do it, well no worries heres a short rundown of what to do...
remeber when using a rb25pfc on a rb20 you MUST upgrade injectors due to the r33 rb25det having 370cc injectors vs the 270cc injectors that came std on the rb20.
download the attatched pdf document, nevermind the fact that its for an r33 gts-t with an rb25det, the pinouts are the same for the rb20 except 2 pins.
on the pinout locate pins 112 and 114 on the ecu plug and carefuly using a small pin or piece of thin stiff wire remove these pins and swap them (you are swapping the triggers for injectors 4 and 6 around).
to do this you'll need to remove the clear ecu backing plug cover and then with the wire on the front side of the ecu there will be a small tab above the pin that needs to be bent back a bit to pull the pin out, i'll try to get pics later.
ok, now that you've swapped these pins start up the pfc and set the injector correction for what ever injectors you have, remember to install a resistor pack if you are using low impedence injectors...
if all went well when you crank the car it should start up and idle well on the first go, verify that afr's are good (which they should be as the rb25 pfc runs stuff silly rich...) and enjoy!
now go tune the car and terrorize r33 owners :O
RB25DET_ECR33_Pinout.pdf
Edited by carl h
https://www.sau.com.au/forums/topic/117123-using-a-rb25det-pfc-on-a-rb20det/
excellent post mate, you have given me hope with running one in my car now. someone said in an earlier post however that the firing order is different?
the link doesnt work also by the way.
Edited by SirRacer
put this on the DIY thread. i reckon it should be attatched to the "power fc frequently asked questions"... perhaps...:thumbsup:
thanks alot for that. should save me about 500 cos the rb20 pfc are that much more expensive than the rb25's.
cheers.
now go tune the car and terrorize r33 owners :)
So you swap the injecting timing, but not the ignition timing. Is that right?
:thumbsup: cheers :D
For sure I'd like to know if anyone has had success with this too. It would save all the RB20 guys lots of money that could be spent on, oh I don't know...... larger injector's maybe. :D
Anyway, super write up and I look forward to the pic's you were talking about and maybe you could fix the link to that pin out so we can download.
I'll be keeping an eye on this thread for sure! :)
Cheers :thumbsup:
perhaps, but if you are taking the car to a pfc tuner then they can copy the fuel/timing maps from the rb20 base map and put it into the pfc.
we did try this on one of my friends cars and it does indeed run fine...i'll see if i can get copies of the base maps from the rb20/25 and do some comparesons between the 2 but i doubt that besides where the vtc kicks in and out it wont be any diffrent...we'll see.
oh and heres a copy of the r32 ecu pinout for anyone caring to compare.
Sydneykid can you explain that comment, seems to have some merit behind it
I thought it was obvious, changing the injector timing (swapping 4 and 6) and NOT swapping the ignition timing means that the injector on #4 fires when the ECU is telling #6 spark plug to fire. I don't know about you, but that seems wrong to me. :P
Logic tells me that if you swap the injector timing you should also swap the ignition timing to match. ;)
Any information ... successfully using a gtr power fc in rb20 would be great
The usual question is 2 AFM's on an RB26 versus 1 AFM on an RB20. Simple answer is to just parrallel up the ECU inputs for the AFM signal. So the ECU thinks that there are 2 AFMs with exactly the same voltage output, which fine and dandy. If you use the RB26 PFC you can add an inlet air temp sensor and use the PFC correction map accordingly.
My own RB20 uses an RB20 PFC, which is now used on the RB31DET. If pushed, I would always use an RB26 PFC on an RB20 in preference to an RB25 PFC.
:thumbsup: cheers :thumbsup:
i dont think that, that logic is quite right.
firing order for all rb motors is the same no, and if it wasnt then you wouldnt be able to run a wasted spark setup on the motors wiring them the same way.
the only diffrence between the 2 ecu's is the vtc trigger, boost solenoid trigger, and clys 4 and 6 triggers being swapped other than that both carry the same exact pinout.
if i could get this picture of the r32 ecu plug to upload you would see what i mean...
we'll slap the pfc back on my friends car this weekend....see if we cant get video proof :blink:.
im hoping redtop and silvertop rb20dets are the same as im sticking in a rb25 powerfc in my r31 shitbox
it should b the same n all
if it dont work ill just use it on my r33 and sell that damn crapola microtech....
you wire it directly to the pinouts, bypassing the wiring loom
im pretty sure anyway. it makes sense, as they are on the pinout for the ecu connector, just not on the loom.
much like the airtemp sensor. the ecu has physical pin, but the loom doesn't
a bit off topic but what does the air temp sensor look like?
ive seen it on the rb26 but it would be nice to see what it physicaly looks like, i might try fitting one to my motor and seeing if the pfc will read it...
    • Gday Thought it was about time I started a build thread! As expected this project has snowballed into a huge financial liability, but unless you’re strong willed and responsible, it’s not a surprise. Background -  My first turbo car was an R32 GTS-4, got my full license and then totalled my Au Falcon a week later, so while trying to sell my RMZ450 dirtbike to buy another car a bloke offered to swap the R32 which at the time I felt like I was ripped off but looking back and seeing prices of those now ($40kish) it was a good deal, I didn’t know enough about these cars to appreciate what I had so sold it before the RB20 blew up. Between here and there, out of 12 cars I’ve owned the note worthy ones are a V8 Lexus SC400 (soarer), a couple of XR6 Turbos and my beloved S15 which I had for about 3 years, picked it up for $12500, repairable write off but she was fine, gun metal grey/pewter and bone stock/unmolested until I got my hands on it. Ended up spending about the value of the car and 280kw, 2 demerit points by the time I got defected and sold it for $14500 (also $40kish in today’s market, rip) Fast forward to the present day, I’m in a much better position financially and daily an MQ Triton (great cars, pipe down Ranger Bois), I cruised marketplace and car sales for a few months looking for another R32, the best deal I could find was an absolute rust bucket half finished project for $12000, until this R33 popped up in Port Macquarie for $18k - unregistered and barely running but decent shape, kept an eye on it for a few weeks and the price steadily dropped, $16k then $15k then $14k, that was the point where I was like shit someone’s gonna snatch this up! It was owned by a young bloke who had big plans but him and his missus just had a baby so smartest move financially for them but big gain for me. So 2 days later I’m towing a car trailer to pick this thing up. Roughly 2 weeks and $3500 later I’m cruising around Newcastle in my beat up R33 all smiles and dose noises! It only needed some basic shit to get it going, coil packs and air flow meter, electrical stuff and all fluids changed, 158k kms and running pretty good, nice smooth engine after oil and coolant flush - when I say coolant I mean it had been filled up with tap water, every gallery and heater element was filled with rust, 8-9 flushes later and still had brown liquid coming out but she’ll be right. The car was painted R34 Bayside Blue at some point but whether it was a cheap job or just not looked after is anyone’s guess, clear coat flaking like sausage roll.  Was rethinking my choices and contemplating life, had it up for sale for $22k - still cheaper than any registered R33 but got little interest, next minute I had an opportunity at work - 6 months overseas for good money, so that was a no brainer, fast forward again and here we are with a 50% finished project. Current Mods - 200ish KW according to butt dyno Was tuned with Apexi PowerFC EBC (old school Greddy Profec)  Stock turbo (more shaft play than a Tinder date gone right) 3inch turbo back Varex muffler  Aftermarket injectors of mystery size, Power FC showed 36% duty cycle at full boost so not behd good size Someone had good intentions but stuck with the stock R33 MAF so we had misfires at 6000rpm due to the MAF hitting 5.2V So far I’ve redone the entire interior with carpet form Car Mats Direct, new Seats and steering wheel from Autotechnica, also sound system by Autobarn (mainly Kicker) Also MCA pro comfort coil overs - Hands down best purchase yet, worlds of improvement over the tired 30yrold shocks Goals - 450kw/600hp on flex tune New paint job - Midnight Purple 2 Engine is at the shop getting rebuilt with forged rods a pistons, new valves and springs, ATI Harmonic balancer, Aeroflow 7.5L sump, rear head drain and oil restrictors as per oil control thread* and cam covers modded for larger breathers, other stuff I can’t recall of the top of my head Parts purchased and to be installed once the engine is done -  Engine loom from Wiring Specialties including these options: Haltech Nexus S3 R35 Coil pack conversion  PRP Dual Trigger kit Fan controller  Other Parts -  262 Kelford Cams Turbo - Hypergear ATR43SS3-ProS with T51R mod (whistly boi) 6 boost manifold (high mount) 50mm Turbosmart Pro gate (plumbed back for legal reasons) HKS Super Turbo Exhaust with High Flow Cat Custom 3.5inch dump and front pipe 1500cc Bosch injectors  Fuel Pump walbro 525 Haltech MAP and IAT sensors Haltech Flex Sensor Fenix Radiator with dual thermo fans LS1 Alternator Kit Oil Filter Relocation from EFI solutions and Cooling pro oil cooler Many other things sitting in my garage waiting for that engine to come back. Progress pics to follow -
    • Losses have to be less with DC coupling. Provided the battery inverter has decent MPP tracking ability - which really shouldn't be a problem. It's not 2005 any more.
    • Hi, Will the R33 GTR rear brake backing plates fit a GTST? I'm struggling to find GTST ones but can find new GTR ones.   Thanks.
    • I also got the same floor mats for a bit of extra bazzaz haha
    • Some more close up pics now that I’m back to working on the car, the loop pile is nice but again haven’t compared it to the other types in person, it’s hard to tell from the pics on the website. View of the hemming on the edges too, it comes in 2 pieces - front and back, honestly very happy with it for anyone on the fence.  Also attached my previous pics from further up as it didn’t let me post them directly before. (Nothing worse than photo bucket pics that aren’t hosted anymore years later)
