Aftermarket pedal & legality?
Has anyone got aftermarket pedals and encountered legality problem with cops or RTA/VicRoads etc?
Reckon any of these would look nice ?
Hey nice timing, im looking to get the second set you got listed there, does anyone know a good shop to get em from and a rough cost, i asked my uncle who does rego inspections, he said he'd pass any aftermarket pedal as long as it has sufficient grip (meaning enough rubber to keep your feet on the bastards) and its not too over the top (sorry goth skyline drivers, no spiked pedals :P ).
yeah i had crappy ones in my astina and the grip mpart was just regular hard plastic, VERY slippery but 9i believe the momo use a proper rubber which squishes and gives grip like it shoul;d, but they also cost like $150 :P are they easy to fit ? as the ones in my astina fit on the bbrake and clutch but the accelerator just didnt want to go on
Here are the ADR regulations. So basically, as long as they are "non slip" and not just bare metal they should be fine. Most of them just bolt to the existing pedals..so is a DIY job.
SECTION K - Other Items
Driving Controls
All driving control pedal faces must have an effective non-slip surface or be covered with a non-slip material. All essential driving controls must function properly. Steering wheel rims, knobs and other devices which have deteriorated to an extent that they are hazardous are unacceptable. Steering wheel covers, if fitted, must be secure
In that case Type-R pedal would be illegal I suppose, as they are only bare metals with huge holes in it...
This is the one that I mean if you never seen on:
yeah i heard drilled pedals are no good, but u can get same effect by having black rubber, looking like the black holes that would normally be there with the drilled pedals. It's even hard to tell from the above photo with it's rubber, or just a drilled hole.
Have you got a pic of your pedals Timmy?
I wonder it must be the old momo model, as the current one they are selling all have rubber inserts as the picture above.
  • 1 month later...
Well, I finally decided to go japan instead of italian... got enuf italian on the knob & steering wheel ;-)
I'm sure the clutch & brakes are ok as they got big chunks of rubber so they won't slip. Not sure about the accelerator as its bare metal.. I remember I've driven a car with metal accelerator, so I guess it's fine?
In my opinion accelerator does not have to be non-slip, as the crucial part are brakes (your foot slip and you wont stop in time and hit something) and clutch (your foot slip while you're in gear then car jumps forward and hit something).... but if your foot slips the accelerator, you slow down.
i think youd stil get done on that, cause say uhad to accelerate out of a situation, and sliiped - or tried to accelerate whilst turning right, and lot power halfway across - id b careful (i have plain drilled metal razo's wit no grip- no probs wit them either...?)
It's a clip on, so if I get done I can easily take it off with two fingers...
As I said I have driven a car with bare metal accelerator pedal, so I'm very sure bare metal is fine with accelerator. I think it was my first car here a 93 CE Lancer which I took it for RWC myself and the bare accelerator pedal pass inspection. Only clutch and brake pedal need the rubber replaced.
I've been pulled over by some nice cops (well if they were nice they wouldn't have pulled me over in the first place), and they told me as far as they know, only the brake has to have rubber on it
he was nice as he let me off having shiny metal aftermarket pedals with GTR printed on them, and I was driving with no shoes coz they were too big and too hard to change gears with lol
 Share
    • I have been looking at some setting on the alarms for the Q60 and what buttons do and so and also been looking for details on the alarm in my V37 which is a standard issue with the car. settings like window roll up and a few others seem to not work at all. i cant seem to find exact info on V37 alarms so Q60 is all i can really go off i have not tried 400Z alarm settings or info yet so that will be next. any one got like a sheet of info on the alarm system in the V37 as all my documents are in japanese but i thought the system would basically be like standard through similar models?
    • I had a fuel smell coming from the drivers rear and pulled the tank out to inspect where it was coming from, turns out the breather hose from the tank to the filler neck was perished. I’m going to Japan next week and I’ll grab it while I’m there  pulled the oil tank apart and started cleaning this crap out of it, some brake cleaner and rags got it looking new again
    • Hmm. Was quite a few years ago now. I think I bought from a crowd in the US called CDT Audio. The speaker is the HD-6. The HD-6CF would have been the better option (based on T-S parameters), but they were discontinued in 4 ohm at that point in time. The HD-6 is a better driver in almost every other way (than the CF) - just not as good in IB. They still do the HD-6. They might even have a more suitable (for IB) option here.https://www.cdtaudio.com/cdtnew22/products/components/woofers/midwoofers/midwoofers.htm But, here's the rub. I was working in the US a lot back then, so I got them delivered to my US office and then just brought them back to OZ myself. I don't know if they will ship to OZ, and it probably wouldn't be great cost-wise anyway. As to results. They're driven direct off the rear channels of my headunit, because the headunit can be setup to run the rears as subs. So, not a lot of power being fed there. Nevertheless, there's no shortage of volume - the sub levels don't need or want to be boosted at all. The bass is definitely not what you would call "tight". It is definitely a bit delayed compared to a proper sub. But, with the great front soundstage and really good 6.5" woofers in the front doors, I'm getting most of the bass detail from the front and the rear is really only to extend the bottom end a bit. Works for what I'm doing. I mean - until recently you couldn't really hold a conversation in my car due to the fuel pump, and for many years I had tyres so noisy (Kumho KU36 at <50 tread depth) that I had to drive with earplugs anyway!
    • curious to know what drivers you chose and the results? quik mafs, says two 6.5s should roughly equate somewhere between a single 8" or 10" driver. i agree that IB is definitely the way to go in most cars imo.
    • S13 and R32 rear suspension geometry is horrible once you lower it (which everyone does). The camber & toe out ramp is very aggressive, hence it's common for the S13 boys/girls to use a S14 or S15 subframe as the geometry is light years ahead. I'm sure the same can be done on R32s, but I don't know anyone that has done that.
