Hi guys, today when I was just having a general look in my engine bay I noticed that one of the rubber hoses coming off my bleed valve was melted to the turbo and had a massive hole in it, the car seemed to drive fine on the way to work this morning and was boosting and holding boost fine so im not sure what this melted hose could of done but I replaced it anyway.
Now anyway as I looked around the engine bay a bit more I noticed their was oil in the vent bits of the BOV (aftermarket Apex'i bov) I then noticed that their was a lot of oil leaking out of one of the intercooler pipes at the bottom of the cooler, this oil is MUCH blacker then the oil thats on the dipstick. I wiped all this oil off and took the car for a short drive and everything seemed fine it wasnt blowing any smoke at all or anything but when I got the car back I had another look and their was more oil leaking out of the bottom intercooler pipe joint bit.
Anyone have any idea what this could be from?
Car is a 1993 RB20DET R32 GTST
Power FC
Bleed Valve, 14psi
GTR Front Mount
Turbo Back Exhaust
Thanks guys!
Turbo seal is the likely culprit. Clean away all the oil you can see and check it in a few days. If it comes back its most likely time to get the turbo seal fixed/replaced.
It could be a once off and may not occur again. If it does come back in a few days you could also turn the boost down a little bit to take some stress off the turbine shaft (rotation speed)
do you have a oil catch can? it could be a bit of blow by
if the pipes that come out of your rocker covers go back into the pipe that runs off the compressor housing and your getting blow by,
that would be the reason for the oil in the cooler and it would be in the turbo and most likely in your throttle body and plenum if you have oil in your bov!
blow by is caused by seals leaking or shagged internals.
having a catch can will capture the oil thats getting in the intake but the original problem is still present, ie: shagged internals or seals.
you are much better off fixing the source of the problem, as apposed to fitting a catch can and just catching the excess oil blow by. if you have oil in the intake piping, something is wrong, is about to fail or is showing signs of fatigue, utlimately it will fail or go bang if it continues
what he said. >_<
you do get a bit of oil up there sometimes after maybe a hard track day or drags, but if your taking it easy and your getting alot of oil you have some problems
    • That is surely the biggest gathering of Stageas in North America, ever!
    • Remember kids - if you can't afford to buy 2 GTRs......
    • I know people cry at the price of the Getrag 12-14k for a conversion now, but it really is a nice mid point. Not going to get change from 10k on a gearset installed.  $30k++ for sequential.   I know you run the risk of a damaged used one and parts are hard to get but as a street car gearbox its really hard to beat. If you enjoy a more traditional manual, its the choice no question.
    • Time to decide what’s more import, your power level or your budget because you’re going to struggle to keep both
    • Our Southern Highlands Cruise is proudly registered with “R U OK?” Day.  Sometimes the best way to check in on your mates is by getting out for a drive together. Sharing a common passion like cars creates the perfect space to chat, connect, and support each other.  A simple “R U OK?” can make all the difference. Let's enjoy the drive, the company, and look out for one another. PLEASE WEAR YELLOW FOR “R U OK?” DAY Sunday 14th September 2025 9:30AM Meeting Crossroads Homemaker Centre 10:00AM Cruise Departure Via Old Hume Hwy 11:45AM Arrival at Mittagong RSL Club Meet Location: Crossroads Homemaker Centre Final Destination: Mittagong RSL Club *Disclaimer* There will be a lead and follow car so no one should get lost. If you would like to attend or bring others along please put your name down and a +1 as numbers will be needed prior! This is NOT a race and we will all be adhering to all road rules. If this is what you want please come to one of our many track days. This is an official SAU:NSW event and will be run under a CAMS permit. One of the things that really sets our club apart is our commitment to being true enthusiasts. When on normal roads we strive to maintain good relations with the authorities as well as the public in general. When attending one of Skylines Australia NSW events please try to: • Be aware of surrounding environment and act accordingly. • Drive courteously on the state’s roads as a true enthusiast should. • Understand how important it is to maintain the good name of SAU NSW and thus, treat others accordingly. • Any misbehavior will not be tolerated and you will be asked to leave.
