  • Replies 76
Yep is is tuned for the mods you list. and you then go by your self to the dyno to get it checked, He guaranteed me if i didn't get a power increase he would write another tune for me after seeing the dyno sheet.
You can get upto 3 seperate tunes sent to you, dyno all 3 and keep the one that suits your car best and send the other 2 back but it costs a bit extra. He was confident he would get it right first time and he did.
Get it right? Or close enough?
Im not trying to sound negative.
But i cant see how someone in another state can tune your car based on what youve "told" them.
Its just pot luck, and it will never be the best tune either.
For $300 it wouldnt wanna be anymore as the tune will never be as good as paying for someone to do it real-time.
Considering you still have to go to a dyno to check, i dunno... im not convinced
What nismod says has some merit to it though.
He is right if the tuner is with you at the dyno you WILL get a better result.
But I did not want to pay big $$$ for a tune as mine is just a mild upgrade.
mabye i could have got a couple more rwkw out of it but I am happy with the results
And like nismod says, he can only go on what you tell him.
Keep in mind there are litrally 1000s of tuners doing it in japan this way, Including some big names.
and yeah it was $150 + $10 delivery + $30 to get the socket soldered in at a tv shop and $80 for the dyno run so all up $270
so the tune was really only half the cost.
I think nissan tune thier cars ritch from the factory, so theoretically its just a matter of adjusting the 'k' value to get the 12:1 afr, im a noob at tuning, so I have been doing a bit of reaserch with the goal of tuning my car, but I would guess this is all he is doing, then you can fine tune from there, I dunno, I have more reaserch to do, and to buy the equipment :unsure:
  • 3 weeks later...
I think nissan tune thier cars ritch from the factory, so theoretically its just a matter of adjusting the 'k' value to get the 12:1 afr, im a noob at tuning, so I have been doing a bit of reaserch with the goal of tuning my car, but I would guess this is all he is doing, then you can fine tune from there, I dunno, I have more reaserch to do, and to buy the equipment :blush:
And what lean out your engine everywhere - thats dumb, thats why noobs shouldn't tune. To tell you the truth I have no idea how this guys sends his programs out every nissan we see at work either needs a fuel pump or the airflow meters are distrorting the real airflow value or the base timing is out 5 or 10 degrees or there is some dumbass idea typical of cheap nissan owners. The chances of getting the mixtures wrong is so much higher with boosted engines.
S/H Ninja - you said your AFM was maxing out before?
The stock AFM should max out at around 200-205 so it would have been well worth your while upgrading to a z32 and getting the appropriate chip to suit. Try winding 4th right out to redline and see if it actually gets there without cutting ignition. When the AFM voltage reaches 5.1V for 3 secs or more your ECU should automatically cut power.
Plus the most you'll ever see out of a set of RB20 stock injectors is 205-208 rwkw so those injectors of yours would be running at 100% or more which is dangerous if the fuel system decides to hiccup for a split second.
I was thinking the same thing, the afm hit max airflow before but now with more power, hence more airflow it doesnt cut?
Was the before dyno run done on the same dyno as the after?
Lastly, I see the run was done in "shoot 3" where usually it would be shoot 6F. Would that affect the power figure? Or is it just a ramp rate thing?
just been reading this topic and my question may apply somewhat
i've got a stock rb20det motor just turbo back exhaust on 10psi atm
i've also got a r33 s2 turbo which im going to be purchasing shortly and i have a fmic/kit which i'm going to be put on the same time as the turbo
with turbo back exhaust, pod, fmic, r33 s2 turbo, is it safe to run 1bar (14psi) without receiving any boost/fuel cuts.. would i need a remap or chip of my stock ecu?
Also why would you scrub out the Ambiant temps and inlet temps unless you have something to hide?
Me thinks you are only making 180rwkw and your tuner put the sensor on your exhaust.
LOL yeah I really need to do that. I dont give a F*#k what sort of power it makes. altho the dyno guy didn't even put the afr's on the printout so i wouldnt put it past him.
Car feels heaps faster and runs perfectly and I have had it tested with a wideband sensor and it is fine.
s*^t some of you guys are negative.
I was just happy with my results and thought I would share. Perhaps next time I will think twice before sharing my mods with others.
dude, you cant blame them for being negative.
these days you truely get what you pay for, and when something real cheap come along, people always think its a scam unless they see some hard proof. and the proof in this case has been tampered with.
I for one wouldnt trust someone over the web to tune my car. every engine is differant, 2 engines with the exact same mods will never make the same power.
just becarefull, cause the money you saved on a proper tune might have to go towards a new engine......
Steve
He knew what he was doing, and the risk. 200rwkw and a nice smooth curve on an RB20 is the result. Time will tell, but it looks like everything went his way this time. I wouldnt get it done, but congrats on the good result mate, thats a happy RB20.
Hey guys - slightly off topic but does anyone know where in Melbourne is good to get a re-map? I know of a couple of places that do it but I am really after someone reputable - I've heard of a 'few' stories of blown RB20s after having had a remap...which is what I am trying to avoid...!! Its not a matter of cost, I personally would rather retain a complete factory ECU rather than a PFC (if possible)...my car is an R32 GTS-t and mods are;
FMIC
HKS 2535
R32 GTR injectors
Q45 AFM
Walbro pump
Any suggestions would be much appreciated...!!!
Cheers,
Chris
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
