  • Replies 43
First you have a go at me for saying things you dont like about your mate.
Then you tell me I love myself for removing offensive comments that are uncalled for made by a user (now banned) who only signed up to hang shit on your mate.
How can I fcuking win?!?! Thought I was doing the right thing in this post. I guess not.
Stick your head up your arse.
Adrian
Adrian
Lol-damned if ya do and damned if ya dont- cant please anyone
I always find it its better to just please your self :)
The track officials can be changed (I highly doubt it and won't be holding my breath), but the sun will always be in your eyes at WB :)
Hopefully Theo rips an 8 as soon as he gets back to WB.
Can be changed but wont be changed
If ya Jimmies mate ya stay :)
haha sorry adrian. :D
lol i added a smiley with tongue poked out hoping you saw i was having a joke around. but ive been a bit jumpy before so fair enuf if you thought i was being a wanker again. lol
in all honesty, i dont know theo well at all. i just get anoyed a bit about alot of baging you give him.
Fair enuf on the banning etc, i just wanted to see what was said!
:laugh:
Just thought i would let every on know we went out for one last past before we headed to sydney for compact attack and ran a new PB of 9.231 @ 153.43mph
Awesome effort Theo
i know it was last month but is there any footage of any of your passes?
Would love to see em :O
GMB
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
