Yeah rally australia will never be the same, along with many other events which he brought alot to.
Life is crazy, he rides a bike breaks every bone several times but lives on only to die of cancer.
dark, didnt see that post in wasteland but its okay. Sheen diserves more than a single thread in the wasteland.
Originally posted by [ryan]
Very sad, but at least he's out of his pain now. Living with Cancer has got to suck.
I think you got it in one there.....and by all accounts he was on the "live hard, die young plan" - sounds like he enjoyed himself while he was here.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
