  • Replies 108
Posted Images
I like the old URL stickers so much better, the one I have on my car is TINY, you have to be right up close to read it.. maybe thats why I get tailgated so much.....
here's a thought, what kind of music are you into? I always thought that a "jimi hendrix" stickers in white would look cool on my back window, cos it's got mega dark tinting..
see imagine just the white writing from this picture (minus the 'the' and 'exhibition'):
stuck on the back of a dark windscreen. I think it would be the shiz. Maybe theres a band or DJ or something that you could stick up there...
just a suggestion.. sometimes I think that ideas like the one i just wrote about are cool.. and then 5 minutes later ill be like: that is the stupidist idea ever, why would I think of that... and then another 5 minutes I'll like it again.. pretty indecisive really...
Sounds like a top idea, coz everyone knows workshop stickers earn free RW K/W and "street cred"
well, i dont drive a stocker like many others on the forums, so i thought that some workshop out there would love free advertising on a decent r33, but it seems not, not even SAU would advertise, even though i believe it would be a top idea..
i guess ill look else where, thanks to foznice for ur ideas man, i might have to look into something else.
i always thought about getting a sticker on my munro, self made, spelling out
Torque Performance
well seeing tha car does make sheetloads of torque, ya, but no performance :O
this would of been if it ended up being a stroker
what makes your car special from all the hundreds of other r33s that have the same mods as you?
maybe speak to the workshop that you get your work done at, and ask them for a sticker?
What makes mine so special you ask? Well the fact the i worked my ass of to save enough money to purchase a REAL jap sports car without any loans, like most guys my age (21yo),and then spend in excess of 10k in the first few months of owning on mods, so its my pride and joy so thats why its so special.
On top of that no real workshops have touched my car, all installs have been done myself or family, which is a top accomplishment for me and has saved me thousands...
im gonna get a custom made sticker it seems.
How is that special?
ohhh joisus...
lol
clearly u cant read, i just told u why its special in my previous post, its best i dont waste my time on here asking ppl like yourself because ive gotta justify myself to u, why i want a sticker?
The thing is, people usually get stickers for a reason. ie a 'Chasers' sticker on a car that had alot of work done at Chasers, a Dr Drift stickers for a car that Dr Drift has actually worked on, or an SAU sticker because of the club they belong to.
You just want a sticker for the sake of it, which i think is pretty "tryhard".
Simple solution: If you want to keep you car as 'unique' as you make it out to be, dont put a goddamn sticker on it like all the other 'unique' lines out there :P
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
