Guys,
Ive got a R33 GTS-25t coupe that i will be wrecking. Car is a 95 Model Series 1.5 the car is black and has done 87,500kms and never registered.
Parts Available
Engine $2500ono (complete with harness and ecu)
Gearbox $1500ono (complete with shifter,clutch and tailshaft)
Diff and Axles $500ono
Brakes $500ono (Front and Rear Callipers, Disc and Lines)
Hubs $400ono (Front and Rear)
Suspension $250ono (Front and Rear)
Exhaust $400ono (3" turbo back)
Intercooler $100 (Standard)
Bonnet $300ono
Front Bar $300ono (complete with blinkers)
Front Bar Reo $100
Headlights $150 each
Front Guards $150 each
Radiator $150 each
Condensor $200ono
Cross Member $300ono
Rear Sub Frame $200ono
Steering Rack $150 ono
Dash Pad $150ono
Steering Wheel $300 (Airbag 1.5 Series)
Interior $300 (Front and Rear Seats, Trims, Parcel Tray, Roof Linning etc)
Boot Trim $150
Rear Bar $100
Tail Lights $100each
Boot Lid $100 (with wing)
Fuel Pump $100
Fuel Tank $100
Wheels $800ono (18" AME Pryder with tyres)
Doors $100 each (complete minus trim)
Nose Cut $300 (Bare)
Rear Cut $1500 (Bare)
Will post more info soon. If anyone is interested in any parts not listed please pm or email me [email protected]. Prices exclude freight and car is located in Sydney
Nathan
Edited by BlownNBoosted
https://www.sau.com.au/forums/topic/118636-wrecking-r33-gts-25t-coupe/
Guest
    • Ok guys thank you very much. GCG highflow it is then 🙂
    • forgot to mention that when it does this it does not kill the engine, but I have not kept the pedal down long enough to let it, as I see no reason to beat up on it as its got to be something simple, small and dumb causing this.  And as soon as I let off pedal, the engine returns to its normal super smooth operation and rpms re-stabilize quickly, once below 4k.
    • neither stumble or cut really seem to be an appropriate term....hard to explain its like a rev limiter but at 4k, but it violently shakes engine and entire vehicle as the rpms will not rise over 4k, even with slow acceleration. as soon as it hits 4k, it sounds like entire spark is lost entirely. plugs were 1.1 which I used as such, but later put in new plugs gapped down to .8 changed back after issue arose when I replaced the coils, still does it with either plug gap...damn and it was all running so good.
    • Oh how times have changed! I actually lean it out relative to my water/methanol injector duty cycle. The methanol adds a lot of fueling and you can then lean it out even more due to reduced knock.
    • Yeah my thoughts are the same, a well thought out WMI setup, would be slightly ahead of just straight E85 and you're also chemically intercooling the charged air, dropping it even further. This is why you need to add so much more fuel as soon as you spray. I remember someone taking me through their set up before (Dennis, has a R33, lives around Cabramatta - no idea if he's still around on this forum). He would target AFR 10:1 on 98, then as WMI ramped on, AFR would lean back up to 11:1. Amazingly, he did this all through his PowerFC, a relay to cut power to his EBC solenoid if there was not enough line pressure on his WMI kit. And of course, if there wasn't any boost made above gate pressure, you wouldn't be accessing the load cells with heaps of timing for WMI. One downside to that rudimentary setup, once the WMI came on, the EBC would unleash the dragon, and of course all the timing. Tyres would fry lol.
