oh and good morning folks
anyway, ill be at auto salon after 12 on sunday, s it would be pretty cool to actually meet some of the members of SAU QLD.. tis somethin im keen on joining in the near future :P
sweet as! we'll be keen to come say hi
preach it brother
:sorcerer:
Haaaaaallelujah!
PS...
OUR KOOLAID HAS BEEN SHIPPED! *parties*
All well and good to be happy about the Koolaid, but WHERE IS MY CAKE!!!! I want Hello Kitty Cake!!!!
Don't hold out on me..... I know you probably ate it all, but I was promised cake.....
jim berry doesnt rebuild clutches for v8 supercar teams for no reason...
No, its because they pay him :P
He will probably also modify the twin plate so it works better.
That is unless we are reading what you said wrong, and he is charging you $500 more than somewhere else.
Id still pay it tho.
Wow, just woke up and I am alone in here with Squizz and Nismogirl!! What an honour. (Genuflection is a given)
I am now officially on Holidays (due to the fact that I will NOT be attending work tonight due to sore eyes (Cannot see myself coming in!!)
Good point, in which case my dick cheese name calling would have to be re-directed. Damn, I hate dick cheese reversals, they never end well.
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
