Im not sure about copper but to anneal steel you heat to red hot and let it cool in air slowly, that makes it soft, if you quench in water it goes hard/brittle.
Whats wrong with your computer Bryn?
No, fat man porn here :D
nah its more an msn problem :happy: im on the internet, but msn cant connect, keeps saying check interenet connection :sick: im stumped
u runnin a firewall?? cos that seems to stuff around msn... disable that and see how you go
this is the thread i read about it in
http://www.skylinesaustralia.com/forums/in...4&hl=anneal
i dont undestand itwas working fine, ive installed nothing just bam it dont work, ive unistalled and reinstaled.. then unistalled re download and zilch
have you done a virus scan on your computer, and also done a complete defragment on it aswell to lcean up HD space?? try those things. if u havent
does any1 know of a T28 turbo & manifold for sale that will fit onto an SR20det engine. i have a mate who is chasing one atm. pm me if you do with price for it. has to bolt onto S14 black top motor.
lol was this the guy from months back that sold his standard turb setup then ran out of cash?
yes same guy, his car has been sittin there not going for ages has motor back in now just needs turbo and manifold and standard exhuast. to get back on road.
the reason is his other car has let go now, broke last night , so he has to fix this one now lol otherwise he has no car.
so if u know of any1 he would be greatful
Morning all.
Alot of people are having trouble with MSN, seems to be the new version, as those with the older versions arent.
As to annealing, I did a bit of research and my verison seems to be the correct way to do it, the guy in that thread just used the wrong terms to describe what he did, he in fact hardened the washers, which is probably the best for copper anyway, but for 50c why bother when they play such a critical role.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
