hmm bait then for a bigger fish ???? lol nah I found when i had fish as long as the tank was a bit dark for the first month they normally all survived. On top of checking the water constantly
BBLLLUUUGGGHHH!!!!
well i'm off to bundaberg 2morro for 2 whole damn weeks of glorious overtime and perpetual on call fun filled hijinx :)
i'll be sure to post some pics of the respray job when i get back tho!
keep on truckin yall :(
Yeah Isacc my car is sorta back together
Im gonna run the high flow at track day as i dont have the time to do the GT30...
My injectors have arrived too so im not waiting on any parts now. The new disc are in and the new pads and fluids are all done. The new clutch is in and biting hard and the car is now sporting a new 250rwkw figure...
In short i have a new company car and dont drive the skyline enough, but im liking the fuel economy im getting from the VZ...
I have a list of stuff ill be selling once the conversion is complete but until then its all being used...
I do have a heavy duty clutch and pressure plate with 70% meat still on it. Plus a full set of standard disc's and some brake pads with 90% meat still on em...
The new rotors are really good they just dont fade...
Its probably a combination of the disc, pad & fluid. But yeah i got the best brakes ive ever tried now...
well i'm pissed at the brake setup i have.. about a year ago i put in new dba slotted rotors and bendix ultimates, pads wore down after 12months and had eaten away at the discs (guessing due to the harsh metal content of the pads) to the point where they only just scraped through minimum thickness after a basic machining (werent warped either). I only did one trackday too :(
hmmm well dont know if id go back to standard rotors unless i was being a tightarse, but i could be interested in the clutch - mines only a few months old but im convinced theres someting wrong with it, gotta get dan to have a look and see
Ill sell my clutch to ya for a carton of coronas... Cold of course... The clutch and pressure plate was worth $600 when i bought them a year ago...
As for the rotors, anyone who wants the whole set and the pads can have them for a carton of caronas also...
The brake pads were $200 and still have 90% meat, and the rotors are worth a few bob i reckon...
But ill post up a for sale thread soon, when i have time...
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
