hahahahha what the hell is zap Skimboards. nice
hey guys what up
You have 3 major skimboard manufactures. Exlie which are damn nice boards, but exxy. Victoria which have been around about 30 years, and Zap. I got a Zap comp. Tappered ends, feels real nice to hold and all. They all are hand made with their own orginal art work :blink:
You did ask...
yeah i didnt say yours was 18500 squiz, i said there was one for sale for that price....
6500, comes with rims lol
its sweet though, i will push him in other direction, toward a r33,
mmmm massive steak roomservice FTW.. the menu said it has the king of all sauces :( lol
and its pissin down in bundaberg...doctor ringing me up when i was halfway back to the motel FTL .. :D on call for these 2 weeks also FTL :(
Tell him the "Beast" and 17 :(
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
