Good morning peoples!! What a lovely day!!
Yes, I just woke up!!
pfft thats a poor effort dave, I JUST GOT UP :D
good morning bishes :sick:;)
P.S yes, i didnt get to bed til 4:30 this morning, and yes i was putting the adapter plate on :rofl: but yes it slightly doesnt fit, but yes i can modify it so it does fit :)
pfft thats a poor effort dave, I JUST GOT UP :O
good morning bishes :):D
P.S yes, i didnt get to bed til 4:30 this morning, and yes i was putting the adapter plate on ;) but yes it slightly doesnt fit, but yes i can modify it so it does fit :sick:
HA HA HA
i knew it...
but thank your lucky stars that you can fix it, remeber shane dont use that crapy instant gasket on it use aryldite :rofl:
Anna Wonderful??:)
ha ha ha
thats only cos your going on a Date with her on friday ;)
nah she alright but i think i have the loudest vomit and i have it on tape to provit :rofl:
HA HA HA
i knew it...
yeahhh, it can be done, but its a bit dodgey, as the plate is 5mm too short on one side (it just so happens the side where the farking diff mounts in the sump) and the holes for the bolts will be right up against that edge :D
wheres my bloody magic wand when i need it ;)
bring them to qld and we will find out which is better then
IS that a Challenge John?
I'll get my hands on a couple of boxes then well do a head to head taste testing comp.
yeahhh, it can be done, but its a bit dodgey, as the plate is 5mm too short on one side (it just so happens the side where the farking diff mounts in the sump) and the holes for the bolts will be right up against that edge ;)
wheres my bloody magic wand when i need it :rofl:
that sucks man but your not getting it redone again?
so will there be more progress or do you have to fix this first?
yes, that is a challenge and though u may be a bit 'wider' then me
bring on the challenge dude.
come time to out eat anyone with donuts, i win all the time
mawahahahahah
mawahahahahah
:laugh: i dont want to see who can eat more donuts ;)
i want to see which donut is better :laugh:
KK's FTW!!
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
