im off, enough mahem for me for one day.
I will pop on again for 15 mins tomorrow, theres so little to do around here....
Theres all of one cop in town and he follows me everywhere I go when I take the car... I hurt my hand earlier on the winch for the boat, cant drive atm, so mum drove home and he followed mum who of course didly boped along at 55 km/h, he was probobly quite disappointed :)
lol ull see pal, its so good infact Zoom Auto Imports rang me and want in on the build :P
i think the trust built 6 speed dog box might have something to do with it
somehow no1 is going to believe that
nice way to spend 12k :huh:
when engine is in and mounted i will post pics...
trust me mate, its being done properly.. boilermaker is making my engine mounts
boilermaker to do the engine mounts, ur very trusting :P
lol APC are rat shit tho
yeah they're evo's are pretty slow rn't they ;)
Oh cool another of the 'my dicks bigger than yours' arguements! :P
But yeah anyway. Im going to have a rant. WTF is it with people wanting to kill sharks that have had a nibble of a person, in a black wetsuit that looks like a seal? The shark is in its natural environment, its seen something that looks like its natural food source, and its gone YUM! Yet we feel it fit to stay out of the water, and try and hunt the thing down. Seriously what in gods name is closing the beach and not going in the water going to achive? Leave the shark alone, its done nothing wrong at all.
i totally agree man
6k just ask vish
ahh k so its not a brand spankin one. so the boasting point isnt all that much now eddie, seeing as u paid the same money as some1 could get a fully rebuilt 33 box with OS Giken gears (well u prolly paid a few k less)
I remember back in the day, johnny had a 6k dog box in his wrx. Life time warrenty or something. He snapped it 3 times...
I am 100% for its how you treat the box is how its going to last. I also know how hard my car is to drive somedays, like hell Id EVER have a car with anything but a normal gearbox in it. But hey, thats sensible me.
yeah and i dont think he (eddie) realises that dog boxes need constantly rebuilding. also for them to be have any decent life span, u cant go shifting at nything below 5k, ur ur just gonna wear the gears, and once they start wearing they wear dramatically fast.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
