yeah but when u harden something, it becomes more brittle.
it all depends on the process used. this isn't hardening the metal, its a similar process to forging in where the metal is essentially compressed to form a tighter molecular structure.
mike any word on the investigations? :woot:
no, they still looking towards me :yes: but i gotta send off a few more forms to them. it wont be sorted out till february i think :wave: i want a new car though! and i've already started planning it. its very frustrating
yes...do you know if hes busy this week? wouldn't mind it back but haven't heard from him.
I said stole. You're not getting it back hehehe.
I'll probably talk to him later today. I'll get him to call you.
try cash converters isaac, you'll usually find most stolen things there. mainly because my friend works there and steals it all and sells it to himself :wave:
no worries, he can just send me a pm later tonight, tell him i can pick it up this weekend.
if you ever need to sell anything, that is worth nothing, go to cash converters at capalaba and talk to doug. tell him michael sent you and he will work something out. very dodgy :wave:
they're called helical cut marc, becuase they actually curve round. you can also have a dog box with helical cut gears as well, just not as strong.
True most road cars run helical cut gears (quieter), silly thing is I was picturing helicals and still wrote angle cut lol. You can actually get angle cut gears too, though afaik they're still as noisy as straight cuts but not as strong so aren't used as often.
I know you can get a dog box without straight cuts (and vice versa), the point of my post was that they are two separate parts of the box :wave:
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
