Ummm, so if you feel like this this morning, dare I ask why you got jiggy with her in the first place??? :laugh:
no one will ever know :P
i dont have pics shanef, she not here! i dont think she would let me take them either :)
didnt look. At work, and I work next to this old fart who talks too loud, complains too much, has too much pride and is very ignorant.
You can tell I love my geariatric co-worker. He studied network engineering for 4 years at tafe, he reckons, and I had to walk him through pinging an IP address.... Fool.
i know, we had a convo bout it when he out it up :laugh:
edit: also i'm at work and cant search for things like that really since the boss views everything i do.
Edited by lilmike86
roflcopter
That is a very complex task though. We had a very expensive phone tech flown up from Sydney to fix a PABX issue, who looked all confused when we explained that a TCP/UDP port didn't necessarily refer to a specific plug in the back of the machine. They didn't charge us for his visit... :laugh:
Hi Lee :)
now check out Lee's av...those are nice boobs :kiss:
Hey karen, the Lady Owner from the mt Gravatt Car wash Place wants you to contact her cos they want to do a special deal for the club, she gave me her card and asked me to give it to you....
lee where were you when i needed cheap seafood :P
oh and how was ur xmas?
Xmass was Awesome :laugh: But now i need Sleep!!! How was yours?
Cheap Seafood you say, he he he we sold out of suitible seafood on Friday the 22nd, it was crazy :laugh:
i know, we had a convo bout it when he out it up :D
:P Sux 2 b U Mike.......
just say its work related!!!!
Xmass was Awesome :) But now i need Sleep!!! How was yours?
Cheap Seafood you say, he he he we sold out of suitible seafood on Friday the 22nd, it was crazy :P
mine was great - i went up to bundaberg to my g/f folks cane farm and actually enjoyed it :laugh:
and i was after some good fish, but didn't know where to go, i ended up getting some red snapper fillets from coles but they were $24/kg :laugh:
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
