OMG the fat mole across the road put far too much salad on this salad wrap! Clearly, the fact that I go in every day and order a CHICKEN and salad wrap, emphasis on the CHICKEN, and using the word CHICKEN first, would mean the salad is to be an accompaniment. Not the main.
f*kn carrot :devil:
BAHAHAHAHA
all the men here are all very aware how much they repulse me :devil:
constipated is probably a more feasible excuse....
i just need to use this face :devil:
I'm guessing it's obvious which ones have made a move... they have acid-related burns on their faces
f*kn carrot :devil:
i effing hate carrot!!!!!!!!!
the thing that grinds my gears the most is when i find little pieces of carrot on my subway... for christ sake they are in seperate containers!! THERE IS NO EXCUSE FOR CROSS CONTAMINATION!!!!
LMAO
u know it!!
either that or walk funny from being shanked in the balloon knot with a razor wire covered baseball bat! :devil:
Barbed wire and PVC pipe also work a treat. Insert pipe, place barbed wire inside pipe, remove pipe
well i made it ok...apparently they half your late return fees if you bring it in to them as opposed to putting it in the slot (waits for sexual connetation to be exploited)...
*holds hand over mouth*
i'm not saying anything u know my sister....
LOL
I would like to thank Anna for making my day with the addition of my favourite panda into her signature. Hugs all around for you!!!!!!
Come and have dinner with me tonight.............
Then some romantic R/C racing and drifting in the moonlight??
I am gone for.........*checks watch* less than an hour and look what happens!!! the same old shit! you guys suck *shakes head*
pfffffffffffft myspace is the coolest
myspace is for ghey's and loners who have no friends and are unable to meet people because their breath smells worse than their ass! you heard the saying "they're beautiful on the inside" yeah, its coz their intestines would look better than their face! :P
well i'm yet to see a ring..... :devil:
LOL
yeah cyborg arm wins EVERY time baybeh!!!!
GO CYBORG!!!!
*pulls out gas axe, cuts off arm at the shoulder*
*continues to beat anna with her own arm* yeah your right it does win everytime, shame you dont :huh:
so which one of your whores are coming to dinner tonight??
no, anna smells :laugh:
LMAO
u know it!!
either that or walk funny from being shanked in the balloon knot with a razor wire covered baseball bat! ;)
you gotta stop taking that from me, its mine ok, buy your own lawyer!
i love that one. so cruel, yet so funny!
well, i'm back now, damn lunch was good :devil:
ahaha not a problem starshine! :devil:
I'm not too sure about the dinner thing yet. Clutch is more than likely coming out tonight, and not going back in til tomorrow night (hoorah for driveability again!) :devil:
I have a very ricer question, but I assure you it is for a good cause!
Where is the cheapest place for me to get a large oval shaped exhaust tip? Super Cheap? Doesn't need to be shiny or special, just needs to be LARGE, and ovalish. But not too oval. More like a semi squashed circle...
myspace is for ghey's and loners who have no friends and are unable to meet people because their breath smells worse than their ass! you heard the saying "they're beautiful on the inside" yeah, its coz their intestines would look better than their face! :huh:
*continues to beat anna with her own arm* yeah your right it does win everytime, shame you dont ;)
could you quote me any more?! jebus!!!! :P
:P
look just shut your pie hole and go on myspace... that's all I have to say
LOL
be back soons....
p.s. intestine face is in this season.... HHHHMPH!!!!!!!! :P
p.p.s don't make me shank you with said bionic arm..... :devil:
ahaha not a problem starshine! :laugh:
IS IT FOR A HELLO KITTY TIP?!?!?!?!?!?!
:devil:
could you quote me any more?! jebus!!!! :huh:
:P
i could, but that would be wasting space ;)
look at my hole and go on myspace... that's all I have to say
whoa :laugh:
you gotta come get it first *waves her severed arm around like a toy* :devil:
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
