this is a first for me. its 2 oclock, i havent had lunch yet and we've been busy most of the day. to top it all off i'm starting to feel really sick
wtf is going on today, seriously?
Same here, been on the go most of the moring, must go eat!!!!
work days seem to be gettin longer and longer
do i get the feeling this will be a slow year instead of a fast year like they've been speeding up more and more over the past few years?
hmmmmmmmm I think it has something to do with you loving balls....
:yes:
:rolleyes:
hrmm
gettin pretty damm dark outside
just opened the blinds for the first time today in my office
only to see its buildin up a storm out there
think it might be wise to grab some food before it poors and im stuck in the building with no food
yes, thought he might of been on his deathbed back in hospital
the old chapp pulled through for us all though
countinues to live on the skyline old skewlers :yes:
joshwa still whore about?
    • Did and sync timing with light
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
